Best way to cool off plenum
Old Jul 15, 2003 | 01:03 AM
bigals87z28's Avatar
Car: Check The Sig
Last time i was at the track, i touched the plenum and i think it took off about 200 layers of skin... you could cook a very small pizza on this thing... and my times showed it... what is the best way to cool it off? I know, bag of ice.. but the track gets mad when you get ice on the track... is there something else anyone has tried to cool off the plenum? Liquid Nitrogen pumped around the plenum? hehehe thanks guys.
Old Jul 15, 2003 | 08:48 AM
Car: Check The Sig
anyone? I saw this Cryo2 stuff in PHR yesterday. They said you can inject it in to the air tube? but then i realized... CO2? Carbon Dioxide? i know its cold.. but.. if my chemestry and all my hs and college sciences serve me right, CO2 would choke the engine because of the low oxygen content?
Old Jul 16, 2003 | 10:58 AM
MdFormula350's Avatar
what engine temp are you running?
i run about 185- 190 now at the track with my passengers fan turned on, and i also just did the tb bypass my plenum doesnt seem to be as hot as in stock form.
Old Jul 16, 2003 | 11:54 AM
Car: Check The Sig
well its about 220 at the track, put i had polished my plenum, which traps heat better then stock. I really wana know if i could cool off the plenum faster then the engine. Oh well, i guess a bag of ice will have to do it. Also, im still searchin for my relays to make the fans turn on.... now which fan is the primary fan, and which fan is the secondary? like wich side?
Old Jul 16, 2003 | 03:42 PM
well primary fan is drivers side, and aux. fan is passengers side.
my relays were located on my drivers side firwall next to the brake booster. there was a set of three relays, the middle one was the secondary (passengers fan) and the last one to the right of the pass. relay was my drivers side.
Old Jul 16, 2003 | 07:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
2 things...
you could use a plastic plenum.... yes someone makes them.. but with all my years on 3rdgen boards, i only know of one.
nitrous cools off your intake....... someone once told me it helps with power or somthing too...
Old Jul 17, 2003 | 12:36 AM
Car: Check The Sig
heheh you know... i thought about that...
i was like... doesnt nawwwws cool stuff off?... then i thought i could tap holes into the plenum and put nitrous jets in there, and have it cooled off like that... but then i thought..... wait.... then im sprayin!! oh man.. oh well.. and ive heard of the plastic plenum.... but never have i seen it being sold.
Old Jul 17, 2003 | 08:57 AM
Jason92Z's Avatar
Car: 08 Nissan Altima
Engine: Stock
Transmission: Stock
OR... you can do the throttle body bypass mod to keep the coolant out of your TB. That makes a huge difference. Even on hot days (105*) and car getting to a temp of about 200*, I can touch my plenum, and its only warm. Look in the tech articles, the info is there.
Old Jul 17, 2003 | 09:00 AM
Car: Check The Sig
check sig.....
Old Jul 17, 2003 | 08:07 PM
Jason92Z's Avatar
Engine: Stock
Transmission: Stock
Aww.. I was so intrigued by the gathering pic, I didnt even read it. That it sorta odd, my plenum doesnt get NEARELY that hot, and mine is polished as well...
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
toronto formula
19
Oct 6, 2015 12:27 PM
