drum to disc conversion, all parts?
Old Apr 20, 2005 | 05:27 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Ok I did a search and couldn't find exactly what I was looking for.
I have an 88 iroc with alum. drums. I just picked up a new rear end, complete from alum. drum to drum, which has new rear gears and posi unit (unknown year, but from a 3rd gen). I intend to install this new rearend into my car but since I've got it lying on the shop floor i decided I may as well swap it to disc brakes. So heres the question, what parts exactly do I need.. and where can I get them? I was told that S-10 pickups rears are the same.. did they come with disc?
I know I'll need calipers, discs, prop. vavle, ... new backing plate? Can someone help me out?? Also.. anyone got a complete 'conversion' kit lying around off a parts car they want to sell? Thanks!
Old Apr 20, 2005 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll need to mod the axel flange of the drum rear end. Note the following for a PBR conversion:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Apr 20, 2005 | 02:22 PM
Brisk's Avatar
hey thanks, that thread is a good read and you listed it out very clearly...
now I just need a donor for the majority of the parts...
Old Apr 20, 2005 | 03:05 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Does going to rear discs require a new proportional valve when the car had rear drums? I'm helping a buddy put my old 91 10-bolt rear left over from my 9" swap into his 88 'vert this weekend.....
Old Apr 21, 2005 | 11:33 AM
JamesC's Avatar
I originally had four-wheel discs on my 85 IROC. When I went to 1LE's all around, I swapped in a new proportioning (combo) valve and the master cylinder from a drum-equipped car, an 88 Camaro. But that's all I can confirm. Try PMing Ed Miller (ebmiller). As the resident brake guru, he may be able to offer some advice.
JamesC
Old Apr 21, 2005 | 11:38 AM
vernw's Avatar
THANKS - will do!
LT1Formula
20
Nov 14, 2015 12:02 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
