cheaper cross drilled rotors.
Old Mar 20, 2002 | 06:12 PM
v8powr's Avatar
wheres a good place i can get some drilled or slotted rotors for my 90 model? front only. the cheapest ive found is 70$ a side.
Old Mar 20, 2002 | 08:36 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
You could try the "free mod" that's in my other post.
https://www.thirdgen.org/techbb2/sho...threadid=92268
Serriously though, the $70 you mentioned is the best price I have heard of. The others I had seen were closer to $100 a piece.
Rob
Old Mar 22, 2002 | 12:55 AM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
Cross-drilled
You can order them through Summitracing the brand is :POWER STOP By Auto specialty 79 a piece and you don't have to have special pads you can have a brake shop install them and use the semi metallic pads on them no harm will be done and the pads will last longer due thee the cooling effect of the drilled rotors
Old Mar 22, 2002 | 01:04 AM
87RS402's Avatar
I've seen pairs on ebay for about $120 a set.
Old Mar 22, 2002 | 02:51 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
$70 a side is a good price for the AutoSpecialty cross-drilled rotors. That's what I paid for mine thru a local brake shop. Cross-drilled rotors aren't "all that" though. It's more cosmetic than anything.
There are slotted rotors selling on eBay for $99 a pair from a place called Hawks Racing. I just scored a pair of 1LE slotted rotors for $149 from them for my brake upgrade. I should receive the rotors next week.
IMHO the slotted rotors are the better way to go. They help the pads last longer and they can withstand higher temps than the cross-drilled rotors.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
