What should I use to polish my Aluminum Driveshaft?
Old Apr 13, 2001 | 07:00 PM
lexussc94's Avatar
Whats the best/fastest stuff to polish an aluminum driveshaft? Thank U
Old Apr 13, 2001 | 07:22 PM
ede's Avatar
ede
if you had access to a lathe i'd chuck it up and use emeroy paper. most likely you don't have a lathe so i'd use a scotch brite pad on a die grinder.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 13, 2001 | 09:07 PM
RARE-ROC-Z's Avatar
actually use mothers aluminum polish and it makes it look chrome. thats it. just that easy!!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Apr 16, 2001 | 10:59 PM
87RS402's Avatar
I'm with Rare-roc, Mothers is the best for polishing. Don't use a rag to put it on. I have always got the best shine using my hand. It's the only thing I use on the semi and the aluminum on the tow trucks. After you get the shine you want use the mothers wax to seal it and help the road grime come off when you wash the undercarriage.
Old Apr 18, 2001 | 07:36 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
If it's real grungy you could start with red scotchbrite, then goto green, then use meguires diamond cut on a wool pad to polish it to a mirror.
Old Apr 18, 2001 | 10:40 PM
CamaroX84's Avatar
Just out of curiousity, why do you want to polish your driveshaft? Do you have a lot of people look under your car? Just curious, that's all.
Old Apr 19, 2001 | 06:56 AM
JoelOl75's Avatar
With the name Lexus SC...
Lexus has alum driveshafts, so maybe....
Old Apr 19, 2001 | 11:58 AM
lexussc94's Avatar
Its for my iroc and I wanted to see how nice it would look if I polished it. To much free time I guess. Thanks for the info guys.
Linson
Oct 24, 2025 02:00 PM
bigjay89gta
Oct 15, 2015 08:04 AM
