EMERGENCY HELP NEEDED BY MORNING, please I wanna fix this Saturday!?!
Old Jan 24, 2003 | 11:15 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I thought it went away, but it didnt... My car has an intermittent problem where it wont start, it will crank till the battery is dead with no trouble, just not fire over.
When it did it before I lost my license (2 months ago) I got fed up and popped off my quick disconnect fuel lines to see what I got, fuel sprayed, so it had pressure. Tried it tonight and fuel didnt spray, but there was fuel in the line.
So since I have been driving it again, it did it last night and tonight, Last night it wouldnt start, Put a battery cart on it after I killed the battery trying to start it, it cranked for about 2 seconds and fired over w/ no problems at all. ( This was after I had driven it to the firehouse from work and washed it)
Tonight It did it at a gas station, But here is the kicker, I came back 2 hours later, and it started up fine. And it was like that 2 months ago too. After it sits for a while its fine.
I know my started is a P.O.S, but (unless we determine it to cause this) it starts the car fine. It sounds like its spinning fast enough to start but that is never accurate, Think the starter just isnt spinning fast enough?
Fuel - Could it be something as simple as a fuel filter, or would it be the fuel pump? It gets fuel, I dont have any stumbling problems or loss of power, never stalls!
I have the SES light on for code 33, I tap on my MAF sensor and it doesnt stumble or anything (Diagnosis I have been told to try) TPS is Brand new and set rite.
What could be my problem, Is my starter trash, is it getting heat soaked? Is it something with code 33, is it a fuel problem
ANY IDEAS ?!?!?
Old Jan 24, 2003 | 11:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
could be the pump going out, but usually they just die and stay dead. Check out the pump's relay and the oil pressure (pump shutoff) safety switch.
Old Jan 24, 2003 | 11:49 PM
86FyrBrd's Avatar
but if it were the switch or relay would it only do it when its hot like that?
Old Jan 25, 2003 | 12:29 AM
86FyrBrd's Avatar
Will my post here help anyone help me, I think it may!
https://www.thirdgen.org/techbb2/sho...87#post1111987
Old Jan 25, 2003 | 08:21 PM
355formulatpi's Avatar
Had the same thing happen to my wifes 96 bird. It would run a few days, and then just crank, and crank! Come back the next day, an started fine! Turned out the pump was bad! Didn't u say, fuel didn't spray this last time? It should! Hope this helps!!!!! Later!!!
Old Jan 25, 2003 | 10:01 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
I agree with the guy above. I had mine go out and thats just like my problems. Next time its doing it have a old ketchup bottle(plastic kind) full of gas and put the top on it. Open the lid so that the hole is open. Have someone crank the motor over and squirt a little bit of fuel at a constant rate through the throttle body. If she starts up and sputters and dies its your pump. The pumps act weird when there hot and going out.
Old Jan 25, 2003 | 11:28 PM
86FyrBrd's Avatar
if you check out my post abot Fixing Code 33, also active on the TPI board here. I think I may have fixed it, the wire going to the E lead on my MAF sensor was cut by my alternator pulley. We'll see,if the problem is gone, its fixed.
My car acted the same when my actual MAF sensor went, that was just a constant problem, not intermittent.
I dunno, I'll post back in a few days and update ya's
Old Jan 26, 2003 | 07:05 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Carry a can of starting fluid with you. Next time it doesn't start shoot a couple seconds worth into the throttle body. This will determine if it's a fuel problem or an electronics problem. I'm betting it's ignition problem.
Old Jan 26, 2003 | 10:39 AM
86FyrBrd's Avatar
Ya think I fixed it?
My other Post?
IROCZ1989
Jan 24, 2016 03:55 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
