Engine Runs Rough With Esc Plugged In
Old May 13, 2005 | 11:17 PM
moneyman380's Avatar
Car: 1991 Z28
88 IROCZ TPI 350 new wires, cap, rotor, plugs, coil
Engine runs fine untill i plug the ESC plug back in ( the connector you unplug to set the base timing) With it unplugged it runs great, just doesnt advance the timing. When i plug it in the engine runs as if its missing.
thinking maybe the esc module is wasted?
Old May 14, 2005 | 01:03 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Thats a possiblility that the module is toast. Or, it could also be some other issue. Whats the base time set to?
Old May 14, 2005 | 01:42 AM
Car: 1991 Z28
6*
Old May 14, 2005 | 02:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Engine Runs Rough With Esc Plugged In
"(the connector you unplug to set the base timing)" yep, that's what it's actually called, "Set Timing Connector," and it only connected to the distributor, and the ECM, not the ESC.
Let us know what's causing the problem.
ESC module Diagnostic chart.
Old May 25, 2005 | 10:38 PM
Car: 1991 Z28
Just getting around to check it, thanks for the chart!
Old Aug 19, 2005 | 10:48 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
i had a problem like this, when i disconect the brown/white wire the car starts and idles perfect, off of static timing. But as soon as i try to run it with that wire plugged in i get a stumbling idle and it stalls. I also get a enormous backfire, which most likely blew my new cat. up, so my idea is that the ESC is fried, or some part between it and the ECM. any ideas? that chart wont work for me as it wont run with the brown/white connector hooked up, but if unhooked i get teh SES light but it runs just fine.
Old Aug 20, 2005 | 02:45 AM
Car: 1991 Z28
I ended up replacing the entire distributor, it had a fried ignition module and some of the internals were about to rust away.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
