91 z28 high rise spoiler fitting on a 91 firebird
Old Mar 12, 2003 | 08:12 AM
777ZLLL's Avatar
Im getting the 91 high rise for my bird.... i just want to know if it will bolt right in place or if i have to drill holes.... (please tell me it will fit in place)
Plus a great help is if anyone has pics.... before/after/durning.. it would all be great thanks.
Old Mar 12, 2003 | 08:53 AM
LT1guy's Avatar
Car: 1987 Trans Am
You'll have to drill holes, unless you're getting the decklid with it. If the new spoiler doesn't cover your existing holes, you'll either have to weld them shut or switch to a non-drilled decklid and just drill the new holes in it.
Old Mar 12, 2003 | 08:59 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I believe deadbird has a Firebird with a Z28 hi-rise spoiler on it. It looks really nice. You might see if his car is in reader's rides.
Old Mar 12, 2003 | 09:06 AM
LT1guy's Avatar
Car: 1987 Trans Am
Do a search on Zephyr, he had one on his car too for a while.
Old Mar 12, 2003 | 12:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Don't know if you'll find anything with that spelling. I had to spell it like this, Zepher, since the correct spelling was already used by my ISP. I've had this name for such a long time, I didn't bother changing it.
Old Mar 12, 2003 | 05:21 PM
panman79's Avatar
Wow, you're the guy with the wicked bad cam on that video I saw.Your car smokes man, I like the way that cam sounds!
Old Mar 12, 2003 | 08:38 PM
Zepher's Avatar
Thanks. And all I had in there was a 305 with a TPI setup on it,
Old Mar 12, 2003 | 11:15 PM
panman79's Avatar
What are the specs on that cam? How bad are you guzzeling gas now? Your polish job on the tpi setup doesn't look too bad either.
Thanks for the inspiration
Old Mar 12, 2003 | 11:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Attached Thumbnails 91 z28 high rise spoiler fitting on a 91 firebird-dcp_0051.jpg
Old Mar 12, 2003 | 11:59 PM
Zepher's Avatar
with 1.5 rockers it was .454/.480 218/220 112lsa, if I remember correctly.
I am not gullzing any gas at the moment since there is no motor in the car. and LT1 is going in very soon. 350rwhp N/A and 500rwhp in the Nitrous.
Old May 18, 2011 | 02:16 PM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Re: 91 z28 high rise spoiler fitting on a 91 firebird
Does the wing fit on the trunk?? I am about to do the same thing and it just looks like there isn't enough space to bolt it down.
Old May 18, 2011 | 09:16 PM
deadbird's Avatar
Engine: TPI 305/ v6
It bolts to the decklid and hangs over the quarter
panels.
Resurrecting a post, via searching, with a good question
Old May 19, 2011 | 01:43 PM
Andrew1320's Avatar
Thanks for the info(: I'll post pics when I get mine done.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
Randomtask2
Aug 13, 2015 01:57 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
