Flex pipe install (GREAT!)
Old Apr 30, 2003 | 08:32 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Here's my latest addition I did today at work (I work right now as a service advisor at Midas)... After too many header gaskets and cracks developing in my y-pipe I decided to make a change to where I had a straight pipe in place of my catalytic converter.. This would be a great mod for those of you with rigid exhaust (which many of our cars suffer from).. This flex section (Midas part number 2E10549) is right where the cat used to be, and I welded a flange/gasket attachment on the rear (leading towards the rear axle and then to the muffler) so the entire y-pipe can now be removed (to service my starter motor if necessary).... It works great, the motor can now torque freely and there is less stress throughout the system... Just thought I'd put it out there for anybody looking for ideas!!
Old Apr 30, 2003 | 08:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Update
btw, the clamp is holding the hanger that attaches to the extension housing of the transmission...
Old May 1, 2003 | 11:20 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
looks good, so now you have no cat. right
Old May 1, 2003 | 12:08 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
oh yeah
i want to get 2 of those for the ta where i have longtubes.. the s extensions hang down too low and if they ever scrape then it would probably break header bolts and ****.. a defanant no no.....
where can i get say some 48" ones? 2 1/2 of course
Old May 1, 2003 | 12:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
The flex section pictured is maybe 12" long... They don't make ones much longer than that (you don't really need much longer than that either)...
Old May 1, 2003 | 01:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: oh yeah
You could put 4 - 12" ones together (j/k)
http://www.jcwhitney.com/product.jht...176678&BQ=jcw2
Old May 1, 2003 | 02:05 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I've had mine installed for about 1/2 year now. I had the shop put one in right behind the cats on the cat back system. I kept breaking donut gaskets on my tes headers due to the stress of the car launching... could be from the spohn sfc and lcas with the 9.5 inch 2400 stall.... I haven't blow out another gasket yet.
Old May 5, 2003 | 08:13 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
correct me if i am wrong but doesnt flexpipe=leaks?
Old May 5, 2003 | 12:27 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
probably not as bad of leaks as missing gaskets from the flexing of the system. I had a shop build my pipe and I've got pretty much these same problems. I think I'm going to need to put some of this stuff in. I'm planning on building my whole exhaust system from scratch though. Hope I have the skills to do it.
Old May 5, 2003 | 12:46 PM
thirdgen88's Avatar
Car: 1995 Corvette
No leaks...
There are no leaks in this style of flex pipe... Infact many oem's use this type of flex pipe from the factory (mostly 1mports).. We had it on the lift, checked for leaks, no leaks!!
Old May 6, 2003 | 01:33 AM
2birds40's Avatar
i hate that stuff it was on a import i owned and i had to replace it like once a year do to it burning out
Old May 6, 2003 | 08:50 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
BADGTA...if your going to run duals just use the s extentions. They hang kinda low but it will most definetly not be the lowest section of your exhaust. The mufflers are MUCH lower. I never hit the s extentions or my pipe for that matter. I did however have a muffler and the pipe ripped off the other night. I went up a small hill at 25mph and my flowmaster caught on a manhole cover.
My advice for life: Screw dual exhaust on a 3rd gen. Its ridiculous. Its low, scrapes, and you can take your friends anywhere in it...or fat chicks (for those who enjoy that kinda thing).
My advice: Get a good set of shorty headers with y pipe (edelbrock TES, hooker 2055s, SLP ect.) and a good catback and be done with it. Then enjoy the ground clearance.
Old Jun 2, 2003 | 08:22 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What kind of driving did you do that gaskets kept breaking?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
mhatfield 14
Oct 24, 2015 07:48 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
