Fuel Pressure Guage - Recommendations
Old Sep 12, 2000 | 10:27 AM
Mike 25th's Avatar
I want to mount an under the hood fuel pressure guage. Any recommendations on which to buy or where to mount? Some people have told me not to run one on the car... why?
Anyway tell me what you think.
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Old Sep 12, 2000 | 08:00 PM
89IROCZ
Guest
Posts: n/a
I am wonderin this also...
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Sep 12, 2000 | 08:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Accel makes one that mounts right on your fuel rail. I've been running one now for 3 yrs. no probs. Just remember the T tape.
If you have a problem,
If no-one else can help,
And if you can find them,
Maybe you can hire....
THE A-TEAM
Old Sep 13, 2000 | 09:39 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Put the Accel guage on the chicken yesterday as part of the 305>350 swap. With the plenum on it mounts so that you have to thread the 2 vacuum lines around it and it comes darn close. And the teflon tape is a mandatory... very hard getting the cheesy setup to seal correctly without it. I was trying to adjust the pressure with the plenum off just to get it close for starting and I pegged the guage (60 psi). It started leaking internally so the guage face was filled with gas and it just got worse. I took it off and am going to return it... I really didn't want to see fuel spewing and a fire on a new motor... I've seen several examples of fried cars from leaking fuel lines (chrysler 2.2/2.5 injected cars are notorious for this... I have a junker in my driveway) and I didn't feel safe with this setup at this time... perhaps a 100 psi guage would be a better setup and maybe more durable.
'89 Formula - Thunderchicken - 5.0 LB9/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Sep 13, 2000 | 09:49 AM
Mike89GTA's Avatar
I have the Accel one too, I would not get it again. I turned up the PSI to like 60 and now the gauge is all screwed up and reads like 10 too high so it is always pegged.
Old Sep 13, 2000 | 11:16 AM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
As for a gauge in the car.. it is a PITA to run a m3echanical gauge in the car and be safe. You need to use a Isolator.. then the line from the isolater and gauge is filled with antifreeze.. They become a pain after a while.
I have an Autometer Electric Fuel Pressure gauge... very accurate. It has the sending unit off the rail.. then a set of wires run into the car and go to a control box.. then the gauge connects to the control box as well. It is great when using Ease or Diacom will tuning your car..
Just my $.02
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
Check out my mods on My '89 Vette
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
