Solutions for when using an EFI tank in a carb'd car.....
Old Apr 6, 2005 | 08:29 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well, if you have read some of my previous posts, you would know that I have been having a problem with my fuel tank. It was an EFI tank(88 2.8L MPFI V6) so I just drilled a hole at the botom of the tank and ran a 90 degree fast flow fitting to stainless steel braided hose as my fuel line. Well, I had a leak at the fitting, and the position of the 90 degree fitting would not allow the muffler heat shield and muffler to bolt up cause it was in the way. I though about using both the fuel supply AND return(supply is 3/8 and the return is 5/16) lines and tee them off into 1 line. Only problem was that I could only use 2 3/8 lines, and my main fuel line was 1/2(-8 AN) and they only make a tee fitting for 3/8 to 3/8 not 3/8 to 1/2. Anyway, I got with a fabricator, and came up with a solution. I had him cut off all the tubes at the top of the sender plate and weld them shut(except for the vent line). One the top was sealed, a hole was drilled in the same location as the supply line, but bigger, 5/8 to be exact. He used a 5/8 diameter stainless steel tube, and ran i down to the bottom of the sender where the fuel pump would be located. He welded it in and bent it 90 degrees at the top. Then I bought a -10 AN hard tube adapter with a pipe bushing reducer to bring it down to -8 AN. I hooked up my fitting from the fuel line and was done. It only cost me about $80 for all the work(cause I can't weld at all!!) and another $15 in the fittings. Here are the pictures.....
Attached Thumbnails Solutions for when using an EFI tank in a carb'd car.....-c-documents-settings-owner
Old Apr 6, 2005 | 08:31 PM
paulmoore's Avatar
Here is pic number 2
Old Apr 6, 2005 | 08:33 PM
paulmoore's Avatar
And here is the third. This pic is of the hole I drilled at the bottom of the tank originally. What I did was simply use a flare cap, so now I have a fuel tank drain plug in case I ever need one. I think that these are pretty handy to have sometimes......
Old Apr 7, 2005 | 07:09 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I punched a hole in my tank and put in a fitting
No leaks thanks to the handmans secret weapon, silicon
Old Apr 7, 2005 | 07:43 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: I punched a hole in my tank and put in a fitting
That's an element in the periodic table. I think you mean silicone. It's not just for breast implants anymore...
Old Apr 7, 2005 | 08:18 PM
sellmanb's Avatar
Car: '86 Berlinetta
and as a note to anyone wanting to do this themselves... you will not want to be welding anything on the gas tank, espescially with fuel in it already. There are TONS of safety measures that you should take before welding on a fuel tank. BBQ Human doesnt taste so good I could imagine.
Old Apr 7, 2005 | 11:36 PM
paulmoore's Avatar
sellmanb: I agree, welding on the gas tank should be done by a professional. They have all the tools to properly clean and remove all gas vapors. But there is one thing. He didn't weld WHILE the sender was in the tank. I actually removed the sender assembly from the tank and he did all the welding to it first. Then, once that was all done, I installed the whole sender assembly back in the tank. No human BBQ for me, well, not unless someone brings the Open Pit BBQ sauce!!!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
willyjoejr
Sep 3, 2015 09:26 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
