headlights acting funky
Old Jul 25, 2002 | 02:19 PM
Joshua Leslie's Avatar
hello
ok,so when I turn on my headlights, sometimes they both come all the way up, sometimes 1 comes up and the other come up halfway, sometimes they dont come up at all.
whenever they dont come up all the way I can move the lights up and down by hand.
sometimes they come up halfway then go up all the way a couple seconds later.
help me!
Old Jul 27, 2002 | 01:18 PM
90flames's Avatar
i know exactly the boat your in, i'm trying to fix the exact same problrm in my 90 firebird, i've looked at new motors for it but its the sometimes it works thing that keeps me from buying one. if you figure it our please let me know
Old Jul 27, 2002 | 02:57 PM
mechanicalmehem's Avatar
sounds like you have either a poor or lose ground or the motors are weak.
Old Jul 27, 2002 | 03:36 PM
1986redbird's Avatar
do a search for this problem, I saw a post a while back which included a fix for this exact problem. It might even be in a tech. art. by now.
Old Jul 28, 2002 | 02:53 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You nead the Hedlight repair kit. It is p/n 444359, $4.95 at http://www.corvettecentral.com/. look up the 84-96 generation, then do a search on "headlights". The kit consists of 3 delrin bushings. The original packing material has gone bad in yours. They also stock new gears and motors, etc. Lon
Old Jul 28, 2002 | 04:36 PM
lr60's Avatar
Firebird, eh? Common problem...probably the driver's side.
Check out http://www.bfranker.badz28.com/headlightfix/
If that doesn't fix it, then someone else did that fix before you. I don't want to buy new motors, either, so I am waiting for the metal gear or someone to sell me a new plastic gear. If anyone knows where to get them let me know......
92 RS 305 TBI 5 spd
97 Firebird "one eyed monk."
Old Jul 28, 2002 | 05:55 PM
BlackBird89's Avatar
How about this one... my passenger side headlight on my '89 Firebird is stuck in the up position. When I got a new (used) motor and connected it nothing happened. When I put connected to the side that I knew worked, it moved. What wires do I need cuz I know this is an electrical problem.
Old Aug 6, 2002 | 03:59 AM
formula4dissent's Avatar
bump
On my 89 formula, I replaced one motor because it was missing completely. Then hooked everthin up to the plugs, expecting instant gratification but alas was denied. Nothing happens at all, no whirring of motors spinning w/o gears meshing... nothing. Control module? What? anyone...
Old Aug 6, 2002 | 07:42 PM
Eternal's Avatar
in the wiring that goes to the light, there is two red wires, those are the power wires for the motors. I'm not sure if the power stays to them when the lights are on but if you could jump those wires with a new wire and see if thats the problem...
Old Aug 8, 2002 | 08:31 PM
Makai's Avatar
http://www.michiganfieroclub.org/headlight.htm
This website is very informative in headlight motor repair
Old Sep 10, 2002 | 09:09 AM
90flames's Avatar
i fixed mine
ok i fixed my headlight with out buying a new motor, and here's how, inside the motor the gear that raises and lowers the headlight rides on three bearings when i tore into mine these were all broken out and this made it so the gear wouldn't make contact and therefore wouldn't raise the light, so my father and i put metal bearing from a brigg's pullstart engin in the motor and it works fine, but it does make a slight clicking noise so when i was at the springfeild swap last week end i picked up the actual ones that go in it, they just look like oversized pencil erasers, and it works with out a hitch now, so that might be somthing to look at and if that's it its not an expensive fix, a lot cheaper than buying a motor.
Old Sep 11, 2002 | 08:54 AM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
Try this website: Trans Am Temple It is geared more toward the 3rd gen headlights. Gives you a cure for two possible problems, namely the main gea being stripped and the second problem being the ground-up plastic bearings.
Old Sep 11, 2002 | 09:08 AM
TA Terror's Avatar
I have the same problem with mine. But after pulling the "bad" motor a pluging it in to the "good" side, the bad motor works fine. On the 87-92 birds the headlight motors work on a 2 wire system that does not use relays. The motors are connected directly to a solid state control module on the firewall. Your best bet is to swap this module with a known good one.
Old Sep 11, 2002 | 03:00 PM
lonsal's Avatar
I forgot that I'd posted a link to Corvette Central back in late July for the parts. Since then I've tooled up and fabricated the parts as well. The TDS 207280 Headlight Repair Kit is $5. It consists of 3 Delrin bushings. The kit repairs the 1987-92 Firebirds, 1987-88 Fiero & 1988-96 Corvette. I'll have the gaskets in stock in roughly a week as well. E-mail me if you need a kit, (web site is almost done).
Lon Salgren
Top-Down Solutions
Old Sep 13, 2002 | 10:20 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Along the same lines, I have a problem with my driverside headlight. Although the light will not pop up, the thing that seems fishy is that the headlight and the parking light will not illuminate at all. The turnsignal (and hazards) will flash but I get nothing from the headlight when I hit the switch in the car. This makes me think it is not merely a headlight motor issue but an electrical (wiring) issue. What should I be checking?
Kevin
Luigytico09
Oct 1, 2015 08:46 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
