Anyone have pics of their heater valve delete?
Old Feb 4, 2004 | 01:42 PM
DreamRoc89's Avatar
Car: '89 Iroc-Z
Engine: 305-E
I was wondering if anyone had some decent pics of their heater valve delete/ simplification. I am planning to toss the setup in favor of a line off the water pump outlet nipple (plugged on stock l03's) and the other line to the rad. heater hose outlet on the pass. side. Trying to get to the point where I can SEE my pass. valve cover.
Old Feb 4, 2004 | 02:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i'll take pics of mine (probably be able to post them next week, i don't have a cam, so i wil have to borrow one). i did it a little diffrently than you descibe. i plugged the connection that is on the framerail, then connected the 2 upper hoses together with 90* junction, just behind the pass. valve cover. the heater works, and it blows cold air when you select it via hvac.
Old Feb 4, 2004 | 02:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hmm. you got me thinking.
when i swap intakes, my intake has rear coolent exit ports.
i suppose i could take coolent from the REAR of the intake manifold, and run the valve to line along the frame rail... hmm.
i think i'll look into that tonight.
Old Feb 4, 2004 | 02:49 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Hmm...I want to get mine working! I've got it still, but it works like a delete....
Old Feb 4, 2004 | 06:11 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Here's mine on an 89 Formula. One line runs from the intake near the thermostat, and and returns to the nipple on the water pump.
Carbs rule.
Attached Thumbnails Anyone have pics of their heater valve delete?-form1.jpg
Old Feb 5, 2004 | 10:18 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
That's a ****ty picture, but its real simple. Just run your hose from the manifold to the nipple closer to the pass side on the heater core, then then driver's side nipple run to the hard line and plug the little passage comming up from the hard line. Then run the out on your hard line to the radiator.
Old Feb 5, 2004 | 05:29 PM
DM91RS's Avatar
Car: 91 RS
Heres one....
Old Feb 5, 2004 | 05:32 PM
DM91RS's Avatar
Car: 91 RS
It's hard to see but I think thats what you're after?
Old Feb 7, 2004 | 06:58 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i had cut a formed elbow from the stock line and plugged it into the rear water inlet on the manifold. the other line was ran to the radiator. i removed the hard line along the passenger wheel well so i had room for the headers. i still have circulation and heat.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
