hydraulic line
Old Jun 27, 2002 | 03:58 PM
spnkzss's Avatar
hydraulic line
I have recently swapped from a auto to a TREMEC Tko. I used all of the third gen hydraulics (all one piece hard plastic line between the master and slave), and a Lakewood bloofproof bellhousing for the Camaro with hydraulic mounts. A week ago the line between the two got a hole burned through it by the header. Now I have a couple questions on how to fix it. I've heard rumors that the '93-95 hydraulics will work just like the '86-'92 but has a steel braided line on it so I can move it against the firewall away from the headers. Is that true? If not does anyone else have an idea on how I can change the line to a braided line for the third gen stuff?
Any help would be greatly appreciated.
Rob
Old Jul 3, 2002 | 06:03 AM
spnkzss's Avatar
Well I answered my own question. I went to the dealership and asked for the master/slave combo for a '94 Camaro. The hookups seem to be identical the '84-'92 style. The '94 stuff bolted right in. The other advantage is it has a steel braided line inbetween that is about 6inches longer than I needed it to be due to the '94 stuff is a pull style clutch and my stuff is a push style. With this extra length I was able to route the line much farther away from the headers.
88SS6SPEED
Nov 11, 2015 07:05 AM
Jorlain
Oct 8, 2015 01:57 AM
topteam54
Oct 6, 2015 12:21 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
jtwoods4
Sep 3, 2015 05:39 PM
