T-5 tranny? strong enough for a 350?
I recently purchased an 86 Trans Am as a donar for its T-5 and 9-bolt rear. It will go into my other 86 TA, it has a stock 5.0 TPI, but I do have a 350 TPI in the works.
Will I have any problems with the tranny? I know that it is not a WC T-5, I have heard contradicting stories on this.
Anyone out there with experiance on this issue, many thanks.
the tranny will take a little bit of abuse. It is the shock and stress of hard launches (slicks) and high torques loads when accelerating. The t-5 is not made for the 350. Thats why it was mated to a 305 or V6. Go with a T-56 or grab a T-5 from mustang they seem to take more abuse.
I spent about a month doing my swap, but that was taking it easy making sure not to screw anything up, I wasnt in any hurry. It could realistically be done in a week. maybe less if you didnt have to do anything else and that was all you worked on. The T-5 is stonger than everyone thinks. mine lasted over 30K miles behind a mild LT1, about 330 hp. I went through 2 clutches before the tranny started messing up, and that was only caused by the last clutch going out and having to drive it, shoving it through the gears. I just rebuilt it with some newer synchros, but Im getting more power and drag radials too, so we'll see how it does. but a T-56 is definately the way to go if you dont want to have to worry about it and have more power ability.
Eric-86sc
Aug 24, 2015 09:01 PM
