Diferences between V8 front susp. coils
Old Nov 20, 2002 | 03:13 AM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
The guy that used to own my 88 iroc, lowered it, but IMO he lowered it too much, I think he either cut the front coils or installed shorter ones.
I want to go back to the stock hight for now, and because I dont have the money right now to buy aftermaket colis, I'm going to get a pair from the wrecking yard.
My question is: Sould I look for any particular coil or donor car? or do all V8 cars (3rd gen F bodies) have the same type of coils?
As for the rear ones, it just has a pair of lowering clamps (or watever the name is) on each coil. I just have to take them off.
Any input will be greatly apreciated
Old Nov 20, 2002 | 03:52 PM
MdFormula350's Avatar
you want to get the iroc-z springs from a camaro or the ws6 springs from a firebird..
Old Nov 20, 2002 | 08:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The IROC and WS6 cars have a heavier spring rate. Use a dial caliper and measure the thinkness of the spring wire. Standard V8 springs will have a thinner wire. Find a set of springs with the same wire thickness and they'll work fine. You could just use regular V8 springs. They'll ride a bit softer. The IROC and WS6 springs offer better handling because of the stiffer springs.
Don't forget that third gen springs from the junk yard are now 10-20 years old. They could be worn out from all the miles of driving.
Old Nov 21, 2002 | 10:24 PM
JP84Z430HP's Avatar
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
I can attest to the worn out springs issue! Mine are original and my car is at least an inch lower than spec....
Arctic Cat ZRT
Oct 27, 2008 08:58 PM
hitman
South Central Region
Mar 17, 2004 01:55 PM
Pearl Jammzz
Feb 16, 2004 12:39 AM
383GTABoy
Sep 28, 2001 12:23 AM
