Why wont my car shift outta 3rd at full throtale
Old Oct 2, 2002 | 10:18 PM
Crazy2.8V6Man's Avatar
I was wondein why when floor it and it kicks down a gear it wont go past what i think is third the car just goes faster and sounds like it is revvin relly high whats wrong. this happens when i in OD also.
Old Oct 2, 2002 | 10:24 PM
87Formula4bbl's Avatar
Car: '87 Formula
In the 700R4 transmissions, GM made it so that if you press the gas pedal more than (2/3 I think it is?), it will automatically kick back down to drive from OD. The only way to fix this and get top speed possible from your 700R4 is to buy the kickdown valve. I dont know the part number but I'm pretty sure it's in the tech section of this site. This would fix your problem.
Old Oct 4, 2002 | 04:34 AM
Pro Built Automatics's Avatar
You will need to block the 4-3 part throttle kick down passages in the TV plunger sleeve. This will allow 3-4 WOT shifts and eliminate 4-3 kickdown at just about anything above 75 mph.
Old Oct 5, 2002 | 02:19 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
adjust your TV cable, thats it.
Old Oct 5, 2002 | 09:24 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
This is the correct answer. Listen to this trans. ***. :hail:
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
