my lockup doesnt work?
Old Oct 5, 2002 | 08:57 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
I have a 1989 gta 700r4 my lockup doesnt work I had a b&m shift kit put in and I had them check the plug for the lockup and he said it was ok he said he would have to take the tranny down and check it out. if anyone can help give me a reason or a cure i would kindly appriciate it thanks.Rick
Old Oct 5, 2002 | 09:14 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
It maybe that the lockup clutch in the convertor is worn out. It is made from the same material as the friction disks in the trans. You might check the computer codes also, the ecm might have a code stored for this problem.
Old Oct 5, 2002 | 11:33 PM
1987gt's Avatar
Car: 1989 GTA
maybe your right about the clutch being warn out because the computer doesnt show any codes unless you have to check for them specificly i used the paper clip deal to check no codes came up.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
