Lt1 intake on a 305?
Old Oct 27, 2002 | 08:09 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
Just wondering if anyone is doing this, and how good it is working for them. I really dont plan on putting my intake on my 305, it will be reserved for the paper weigh of a 350 in my garage. seems like the 305 cant flow enough to need this intake to me.
Also, what kind of heads do you recomend on my motor. My setup so far is: 52mm TB, Hot cam, 1:6 rockers, AFPR, edelbrock headers, 3.73's with a 5 speed. dont really know what heads to go with. i was gonna do the vortec, scoggin dickey manifold swap, but after going on Johns website i have decided to go with the Lt1 intake (BTW:John, very good website )
Thanks guys
Old Oct 27, 2002 | 10:42 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ron mullins on this board put an LT1 intake on his 305..he used world products s/r torquer heads and a lt1 cam....and he said it really woke it up...
im also going this way....im goin to use my stock heads fully ported and gonna use a little more cam...
be ready for flamers to pop in this post...theyll tell you that its to much intake and all this bs...if want to hear it from ron talk to him hes done it. and not listend to people who havent
Old Oct 27, 2002 | 11:07 PM
90iroc5spd's Avatar
f-crazy, good point. I dont really want to hear from someone who hasn't done it, but still has an opinion. You cant really generate an opinion if you havent done it! I was wondering because i am going to use the lt1 intake on my 350, but until i put the motor in my car why not slap the intake on the stock 305 if it will help it.
thanks for the post.
Old Oct 27, 2002 | 11:44 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
i've often wondered this and just took the general opinion of the crowd that it was too much for the 305 but never really knew. but since you already have the intake and plan on using it on the 350, why not try it out and add a second opinion to if it helps or not?
Old Oct 29, 2002 | 09:35 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
exactly why not use it?...whats the worst that would happen..youd have to take it off and put the tpi back on...
if u guys remember correctly..back in the earlly-mid 90's gm put out a 4.8 liter with a lt1 type intake on it...there "mini lt1" performed pretty well i think it was 230 horse and about 300 ft pounds...and it ran like a raped ape up to 6500
im goin this way...ya gotta keep up with lt1s on the freeway
Old Oct 30, 2002 | 10:49 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i've seen his intake in person and it looks killer under the hood of his Formula
Old Oct 30, 2002 | 03:38 PM
90iroc5spd's Avatar
I dont have the intake yet, i bought it, it is still in the mail. I think i will try it on the 305 though, since it will be a while till the 350 is done ($$$)
I'll let ya know how it turns out, but i would still like to hear from some more people who have done it
thanks guys
Old Nov 1, 2002 | 03:14 AM
Odyssey's Avatar
Watch out if doesn't fit. I bought mine from John and found out when I went to put it on it won't fit my heads. The water ports were sticking out past the lips of the intake. John didn't want to take it back even though it was still basically "new". He wanted to charge me a %25 restocking fee which is BS if you ask me. I hope it works out for you though...
Old Nov 1, 2002 | 10:54 AM
90iroc5spd's Avatar
it didnt fit on what heads, stock ones or the sprotsmans in your sig? I have an entire LO3 sittin it the garage so i try it on some stock heads before i yank my intake. I really wish it could be used on some vortec heads.........
I didnt buy mine from john anyway, i got it from ebay (and the guy ripped me on shipping) so im doing the work on it, hope i dont screw it up
Old Nov 1, 2002 | 01:16 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
The re-stocking fee is because of what you CHANGED to the intake. You port matched it for your heads and started working on changing the bolt pattern to the other style.
All that makes it tougher to sell. How long must I wait till a customer comes along with the same request? In other words, I'd be stuck with it.
Old Nov 1, 2002 | 04:40 PM
90iroc5spd's Avatar
hey john, as long as i have you here. have you had many guys putting this intake on 305's? and have you had any issues with the motors running hot since you dont have a regular sized upper radiator hose coming off the intake? im kind of worried that those two heater hoses to the remote thermostat wont flow enough to cool my motor in the summer.
(and i dont disagree with your restocking fee)
Old Nov 1, 2002 | 07:25 PM
Engine: 4.0L
I don't know how many intakes I've done for 305 engines. Dozens I think. Not alot of feedback so I am clueless on the performance gains.
The 3/4" hoses won't make you run hot. They are not smaller the TPI coolant lines either. I simply duplicated the TPI coolant routing, I did lengthing it though.
The water ports out of each head aren't much bigger then 3/4" in most cases. They in turn went directly to the thermostat then back to the radiator via the upper radiator hose.
I just lengthened the routing to a remote t-stat and it in turn returns to the radiator through a stock (cut) upper hose.
Old Nov 2, 2002 | 12:16 PM
90iroc5spd's Avatar
i would think that it would take longer for the thermostat to open though since before it does no coolant is circulating to the thermostat. the coolant in those hoses would take longer to come to temp. ?? any problems with that?
Old Nov 2, 2002 | 05:02 PM
Engine: 4.0L
Drill 3 small holes in the thermostat. That will alow coolant to always circulate slightly.
Old Nov 2, 2002 | 09:47 PM
Vader's Avatar
That was the L99, and is a good source for LT1 intakes and parts. Everything on top except for th einjectors is the same, including the coolant and EGR. For a 265 inch engine, it did pretty well in the heavy cars that got it.
Old Nov 4, 2002 | 12:09 AM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
What cars were those L99's put in. I would love to get one of those
Old Nov 4, 2002 | 05:35 AM
Engine: 4.0L
Caprice, Roadmaster, Fleetwood, Impala.
Old Nov 4, 2002 | 05:19 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
look for a land yaht lol....there were heavy cars...upwards of 4500 pounds....as vader and i said...there performed pretty well considering they had to move 2 1/2 tons
Old Nov 4, 2002 | 08:23 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I say GO FOR IT! I'm a big fan of the 305 despite what others say. I think it would be a good match for the 305. They like to rev anyways. At least my old internally stock one did.... in front of my 6-spd that is! Good luck!
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
