lt1 and 3rg gen rad hoses?
Old Jul 25, 2003 | 07:10 PM
thatsme's Avatar
What hoses are everyone using with an lt1 and 3rd gen radiator.
Did anyne find stock ones for any vehicle that fit or did everyone have them made up?.
Old Jul 26, 2003 | 08:38 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
This is what Markolc did and I copied it....works perfectly. This is copied from another post........
Quote by Markolc:
You can use your stock thirdgen radiator to make things bolt up much easier. You can IM me with questions if you'd like...My SN is Thirdgen Camaro.
About the cooling setup, It's not very difficult to figure out. You can EASILY reuse your existing radiator and fan setup...you just run your lines slightly differently. Here're the pieces you need:
'94 corvette lower radiator hose
'95 Camaro Z28 upper radiator hose
3/8" brass coupling
18" 3/8" ruber cooling line
6' 5/8" heater hose
6' 3/4" heater hose
assorted hose clamps
Two caps for about a 5/8" tube.
Here's how you need to run this using the stock radiator: use the 'vette lower radiator hose to connect the radiator to the gooseneck on the LT1 water pump. Use the Camaro upper radiator hose to connect the radiator to the LT1 water pump. (you may have to grind off a little of your existing radiator shroud, but it's very minor work). Now on the upper radiator hose, there will be a 3/8" rubber line kinda splicing off of it. What you need to do with that is take the brass coupling, put it on, and take the 3/8" extra piece of tubing you bought and connect it to the brass coupling, therefore extending the tube coming off the upper radiator hose. Now route that 3/8" hose under the throttle body so it pokes out past the TB on the passenger side. There you will snake it around and connect it straight to a metal coolant line that runs along the bolts on the passenger side of the intake all the way to the back of the heads. That will eliminate the need for you using the TB to pass coolant, and giving you the cheap TB bypass mod. Now to route the lines to the heater core. Take 6' of 3/4" coolant line and run it from the upper port on the water pump all the way to the 3/4" opening on the heater core. Since you have 6' to play with, you can route it pretty much anyway the hell you want (they sell pre cut 6' rolls of this stuff for $3.99 at the auto parts stores). Now take the 5/8" heater hose and run it from the lower port on the water pump (BTW, both the ports for the heater core on the water ppump are on the passenger side) and run it all the way to the 5/8" port on the heater core. Now you have pretty much all the lines run. This is now an optional/conditional point of the coolant routing. Are you going to be using the stock LT1 oil cooler? If you are, you will not have to buy the 2 caps for mentioned in the parts list, but you will have to buy 6 more feet of 5/8" cooling tubing. There'll be one port one the drivers side of the waterpump for the oil cooler. You run a hose from that port to the oil cooler, and a hose from the oil cooler back to the opening in your radiator (which was originally used as a return from the heater core in a stock setup). If you do not plan to use the oil cooler, just block the ports on the radiator and waterpump. You'll be all set. That's the whole cooling setup. Not too hard if you understand it, and I think I explained it fairly well.
Old Jul 26, 2003 | 12:19 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
holy cow!
i think this post answered one of my questions.
i was told by someone on here before not to use the 95 upper hose. since then i havent been able to figure out how to hook all that up. this is a good start.
the only other thing im not clear on then is the coolant line coming out of the throttle body.
do i just cap ot ogff then?
Old Jun 19, 2005 | 11:29 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
The 95 upper hose i bought doesnt have a 3/8 hose coming off it can i just use the top hole under my radiator cap that has a heater core plug in it? I was gonna get a 3/8 fitting in it to run it to the head lines.
Old Jun 20, 2005 | 09:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I just used a 4th gen radiator...made hooking up the waterpump easier with the connector that would goto the oil cooler on the Camaro engines and the return line coming from the back of the heads. Then I cut down the plastic LT1 radiator support, drilled the bolt holes to match up the mounting holes on the radiator support and screwed it down.
Old Jun 20, 2005 | 10:36 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
can i run the heater core tap on the top of my radiator to the return line for the heads?
Old Jun 25, 2005 | 10:00 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
OK guys use a 93 hose 95 isnt as good.The 95 doest have the 3/8 hose on it. what did everyone do with there heater core hoses mine looks horrible and i cant get my corvette covers to fit because they are in the way.
Old Jun 26, 2005 | 12:17 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I've used the above method twice and both times, the '95 hoses I bought had the 3/8 on it. You must have gotten the wrong hose from the store.
midge54
Dec 27, 2019 04:14 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
midge54
Aug 29, 2015 09:51 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
