how much fluid does a T5 take?
Old Mar 8, 2004 | 01:51 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Just like the title says, I want to know how much fluid a non WC T5 takes?
Old Mar 8, 2004 | 02:48 PM
Doward's Avatar
2.5 qts of Dexron III. YES ATF!
Old Mar 8, 2004 | 02:51 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Dowards quote sounds about right. However, I always just filled tell it comes out the fill hole which is what the manual says. Never really "counted".
Tip, for me it is easier to pour the fluid in the shifter hole, then it is to try and get it in thru the fill hole.
Old Mar 8, 2004 | 04:56 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
Yup, I always fill it up so that it is level with the bottom of the fill hole like the manuals say (i.e. - Like Dale said, it will start running out of the fill hole).
Through the shifter hole? Heh, I use one of those handy dandy pumps you screw onto the fluid bottle, something like $6 or $8 at my local parts store. You can change the tranny fluid in no time with one of those.
Non World class T5 transmissions use 80-90w gear oil. World class T5 transmissions use Dexron II or III ATF. The WC use ATF because of design changes, namely the addition of some needle bearings. The gear oil won't lubricate the needle bearings in a WC very well.
Now, weither or not it would hurt to use ATF in a Non-WC, I don't know. I wouldn't think so. I've always just used 80-90w in my Non-WC and ATF in my WC. The Non-WC had 240,000 (bought at 197,000) on it when I sold the car in January of this year.
Old Mar 8, 2004 | 10:05 PM
Axle/Gears: 4.10
How often are you supposed to change tranny fluid? The same as an automatic? around every 30k or so?
Old Mar 9, 2004 | 05:44 AM
Dale's Avatar
Engine: 350 S-TPI
I cant say that ive went and changed it. I usually end up spilling some pulling driveshafts, dropping for clutch etc.
My brothers truck has 138k on it, and I just changed the clutch for the first time, never changed fluid, or anything.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
