confused about carrier need some help???
Old Aug 1, 2002 | 11:27 PM
1989camarorsrs's Avatar
Before my accident wiht my 89 camaro i had purchased 3.42 gears 3.08 and lower carrier meaning 2 series carrier. Now i bout a 92 camaro and i wanna get a differential, im looking in jegs right now at auburn posis. Woud this be the right its 28 spline which my car has right now its a 92, and its for 3.08 -down(meaning a series 2 carrier which i had purchased for my first89) right???? This stuffs confusing oh yea and the part number in jegs is 109-542041 ....324.99
Old Aug 2, 2002 | 07:18 AM
82camaro's Avatar
Car: 82 camaro SC
The 'series' of the gears and carrier must be the same. Are you planning on using the 2 series 3.42's from your '89. If so, you need a 2 series carrier.
Old Aug 2, 2002 | 08:58 AM
Yea thats what i thought, but in jegs it doesnt state this carrier is for 2 series or 3 it says 308 and lower or 323 and higher. Im assuming 3.08 and lower is a 2 series right??
Old Aug 2, 2002 | 02:12 PM
Old Aug 2, 2002 | 03:06 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
3.08 and lower is series 2. I highly suggest being very very positive that you need series 2. If the ring gear is not extremely thick you have a series 3 carrier. If you are absolutely sure then go with the series 2. The thing is I was SURE that I had a series 2 carrier, untill I bought new gears. Then, suprise suprise, it turns out the calculations I did were off and I had a series 3 carrier.
look on your ring gear and look for the stamped number. 42:13 or something similar should be stamped there. Do the math to be absolutely sure you have the correct carrier.
(42:13 means 42/13=3.23 gears. 41:11=3.73 gears and so on.)
Old Aug 2, 2002 | 03:47 PM
well i know my gears are for a series 2 carrier i was asking if the differential i am looking at in the jegs magazine is series 2 or 3.
Galaxie500XL
Feb 1, 2020 04:53 AM
gord327
Oct 3, 2015 01:25 PM
bubbaz28
Sep 18, 2015 02:09 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
