Factory and Custom Memcals Available
Axle/Gears: 4.11 posi Ford 9"
Have a few factory memcals I've collected. As far as I know all are good (not fried/"broken" to my knowledge).
FACTORY MEMCALS
AUM (#3236) - $35 shipped.
ACXS (#1088) - $35 shipped.
ARXT (#8176) - looks to be brand new, $45 shipped
AUJL (#1615 0499) - looks to be brand new, $40 shipped
NON-FACTORY MEMCALS
Jet Stage II Performance Chip, Stage II - Off Road Only, worked great in my 305 dual cat car before going to the 383 SR. This is a standard lookinbg memcal (not a piggyback) with their chip installed. Part number is #192135 for a '91 Firebird 305 TPI (VIN F) with the dual cats and manual tranny. $85 shipped.
ADS SuperChip for the same car. Will get part number this evening. This is a piggyback set up similar to Craig Moates' piggy back board. Has chip socket (no ZIF connector tho) and chip does not appear to be soldered in. $45 shipped.
FACTORY MEMCALS
NON-FACTORY MEMCALS
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
I was wondering if you had a memcal for a 350 MAF ECU w/ automatic transmission?
Thanks!!!
I upgraded from my 305 to a 350 and ive got a burnt Eprom being sent to me, but i need the 350 MAF Memcal..
Thanks!!!
Thanks!!!
Thanks!!!
All I've got are the ones shown above. I'll try to find out tomorrow if one of them is for a 350 MAF car.
On my 305 TPI/ T5 combination, it ran great! Got highway mileage of 22-24MPG, but only about 14-15 in town. I liked it.
Now - I'll also be honest with ya, I've researched it personally since I'm into burning my own proms now. The changes they made are in the two VE tables, the spark/timing tables, and when and how much PE (acceleration changes) is used. Not rocket science by any means, but if you don't do your own custom proms I think you'll like the set up. Car was fun to drive, but it also doesn't compare to the fun I now have with my 383 SuperRam setup (and naturally never would).
Never ran anything on the 383 SR but a custom DIY chip.
Best thing to do is go to www.moates.net, buy the gear and do it yourself. I wasted $300 on a custom chip that was terrible, should have spent the money on learning how to do it myself to begin with. And I'm still learning.....
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Here is what the various memcals are for:
AUM = 86 5.0 w/ auto
ACXS = 87 5.0 w/ 700r4, and 2.73 gears
ARXT = 89 2.8 w/ TH125C, and 2.84 gears
AUJL = 89 5.7 w/ 700r4, and 2.77 gears
All are for MAF cars with `165 ECMs, less the 2.8, which is speed density and uses a `730 ECM.
WOW! Thanks for that info, although I'm quite surprised about the '89 cars using the 165 ECM, I thought those were 730 based. Guess you learn something new every day. Again, Thanks!
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
The V8 cars with the 7730 speed density ECM started in 90
However, the 89 memcal has a superior prom to the earlier MAF chips -- It has the cold start injector eliminated etc. Newest version of the MAF code
Thanks for clarifying that for me!!! Since mine is a 91, all I know much about is the 730 and $8D (AXYC, AUJP, etc.)
gta892000
Sep 16, 2015 12:37 AM
