MSD 6A-don't bad mouth it!
OK, I've seen the not so favorable posts about msd-but I have to disagree!!!
We just got back from a 7500mile 'round the country road trip; the car started sputtering and back firing under load only-and a long ways from home!
After scanning it and checking fuel press and everything there looked good I unhooked the msd-and then it wouldn't even start! There was a little spark without the msd, but not enough to even start it with the failed coil!
I installed a new coil without the msd and then it would fire right up-so I rewired the msd again and we were back on the road again.
So the msd kept us from being dead in the road!!!
And yea, it was a great trip, just not enough time.
What exactly is it that the box does. I just went out and bought $300 worth of MSD for my trans am. I bought a ready to run distributor and a blaster coil. I didn't get the box, and now when I hooked all the MSD stuff up, my tach doesnt work (nothing to wire it to). I have heard that with the box, you can set a rev limit and other stuff but what exactly does the box do?????
Steve
Steve
Car: 99 Formula
Axle/Gears: 342
I've never heard anyone bad mouth MSD. Only that an aftermarket ingition setup isn't really needed for most of our setups.
Steve
Steve
HI, Sorry I'm not much of a MSD guy. Been more of the Mallory type. I'll be switching over to the MSD as soon as I go forced induction
. But to maybe help you with your Tach problem, your tach wire connects to the negative side of the coil. Thats the one that is triggered by the distributer. I belive if memory serves correctly that the tach wire coming from the dash is white I may be mistaken. If MSD tach hookups are different, someone please correct me. I do know thats where it goes for Mallory ignitions. Hope I was able to help
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
Just a side note..
I bought a worn out old msd6 off of ebay for $50.00; it ran for all of about 60 seconds and died out down the road 200 ft from my house. I sent it in to MSD for repair...$15.00 min - $60.00 max, and waited. Just thought I might have wired somthing amiss...never gave it a second thought, just wrote it up to bad luck.
2 weeks later... a brand new MSD6 arrived, in the box with all connectors and documentation...no invoice...no charge.
MSD ROCKS!
MSD ROCKS!
the gentleman up a few posts was correct. the tach wire is white, and it is in one of the plugs that connects to the stock distributor. Unfortunately, GM uses an in-line filter in series with the tach's so in order to get the MSD ignition output to work you have to find the filter and bypass it. I am still looking for it myself
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I have a 6al box and have no complaints....i would like to get a digital box for more control though. good ignition though
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I just ordered an MSD-6A for my 1991 Z28 (5.7 TPI L98)......sohuld be hooking it up next spring.....!! Hope it works well....
Car: '89 GTA
Engine: 427 BBC
Transmission: TH-350
Car: 1989 Iroc Z L98
My '89 had no such filter. I hooked the white wire up to the tach output on the box and away I went. When the motor comes up really hard, the tach won't keep up though. It will kinda "bounce" around. My 5" silver Sport-Comp is way more accurate. Just be sure that if you run a box, don't hook up your tach to the coil. MSD says it'll screw up the box, and I have friend who'll vouch for that. Only use the tach output on the side of the box. - Also, as stated, the box fires the plug multiple times per fire, instead of the typical single fire. -
Car: '91 Camaro RS
it might be important to note though, that the MSD boxes only provide multiple sparks at lower rpms. once you start to build rpm, you get a single spark, but it last longer and is hotter than a regular spark. I forget at exactly what rpm that takes place though
Car: '91 Camaro RS
ya i think it depends on the model of the box from MSD....if you put it on a scope you can figure out exactly where it happens.
Car: 88 Firebird
I know that using msd's specific harness for our thirdgens, i had no problems at all. My 88 has the small cap hei, i didn't have to change the tach at all, didn't have to cut any wires or add anything, all in all it was the easiest hookup i have done. The tach didn't need any fancy filter or anything, and my tach doesn' "bounce" as some have said. Has anyone else used the harness that they sell?
Car: 88 Firebird
I got mine off the shelf at kragen autoparts here in ca but, the part number from msd is MSD-8876. Just put that in on the summit website, at 27.00 it isn't cheap, but sure as hell makes things simple.
I'm planning on running an autometer tach anyway so I won't even mess with the harness. I also plan on getting the 6AL box so that I don't over rev my engine.
Steve
Steve
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
