Guages:odometer problem/ needle removal
Old Apr 7, 2003 | 01:06 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Transmission: WCT5
ok so im riding down the road and i hit a really huge bump. I look at my odometer and i went from 81K miles to 103K miles. I opened the dash up and the gears on the odometer are broken. How would i go about fixing this problem? How do i take the guage needles off? Also while im in there i want to replace the damn orange condom bulbs to white. How do i do that?
Old Apr 8, 2003 | 12:17 PM
dd85T/A's Avatar
Car: 85 T/A
If the gears are broken, then you will need to replace the spdo.
Buy a used one and reset the odometer to match how many miles you had. As for the lights I just replaced all the orange ones with clear 168's. Looks better I think.
Old Apr 8, 2003 | 04:52 PM
Car: 1991 Camaro RS
Transmission: WCT5
do you have a pic of your white guages?
Old Apr 8, 2003 | 05:06 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the needles are easy to take off, just take your time and be careful. you need to pry them off, but you MUST apply pressure directly away from the gauge. if you try to pry it off at an angle, you will snap the little post and then you're fuc*ed. i did this when i was taking the needles off to paint them, good thing i was taking them off the old 85mph speed and not the 145mph
Old Apr 8, 2003 | 09:50 PM
cubedhead's Avatar
hey i found a replacment tac. and spedo. gauge in the junkyard and im gonna put it in my 87' Trans Am, but i cant my gauge cover off i un-did all the bolts. But there seems to be a clip or something above the AC/Heat controls......no clue????? some help would be great. Its an '87 Trans am
Old Apr 9, 2003 | 06:21 AM
dd85T/A's Avatar
Car: 85 T/A
You need to unplug the connectors on the switches mounted to the guage bezel. You should be able to pull it out enough to reach the connectors easy. Tilt it down from the top.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Stroopwafel
Sep 11, 2015 06:38 AM
