Oil pressure sending unit
Old Apr 6, 2002 | 02:45 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I'm finishing up swapping from TBI to TPI ('88 setup)....the TPI harness has 2 plugs for the oil pressure sending unit...one on top behind the intake manifold, and one on the side of the block. Do I use both? Or which should I use? Thanks.
Old Apr 6, 2002 | 06:09 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The only one I have hooked up is the one on top of the oil filter.
Old Apr 6, 2002 | 09:06 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
the one on the side of the block is used to cut the power off to the fuel pump in the event of lost oil pressure.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
