oil pressure sending unit location
Old Feb 28, 2002 | 01:12 PM
speedfreaker's Avatar
where is and how do i change my oil pressure sending unit is it difficult time consuming thanks
Old Feb 28, 2002 | 04:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
On some SBC's its down above the oil filter. On some it's by the distributor, threaded into the back wall of the block.
FWIW, I used the tee off an 86 iroc on my 86 Monte. REmoved the above - oil filter one,and used the one by the distrib. For z-bar clearance
Old Feb 28, 2002 | 04:25 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
It should be at the back of the engine near the distributor. It's a barrel type object probably 2.5" long about 1.5" wide. Unscrew it, screw in the new one. Ultra simple.
Old Mar 1, 2002 | 09:42 AM
thanks guys
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
