Spohn Adj Torque Arm
Old Jul 27, 2003 | 09:48 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
How do I adjust this thing?
Do I put the angle finder on the driveshaft and see what the reading is then move it to the arm itself and then adjust accordingly?...
Thanks.
Old Jul 29, 2003 | 01:03 PM
IHI's Avatar
IHI
you want the weight of the car to be on the tires for an accurate reading, then if the angle finder has a magnetic base, we usually stick it on top of the pinion yoke where the driveshaft bolts into.
Old Jul 30, 2003 | 08:42 PM
Racer3313's Avatar
Car: 1991 Camaro RS
Engine: 305 LO3
Axle/Gears: Ford 9" 3.70 gears
Just purchased and installed the torque arm. According to the directions: "Using an angle finder place it on the driveshaft (flat smooth spot) and record the angle indicated. Next, place the angel finder on the flat surface where the torque arm mounts to the rear end (this surface is parallel with the pinion shaft) record angle indicated."
You subtract the pinion angle from the driveshaft angle to get your "true" pinion angle.
For better bite you need to run negative true pinion angle.
Hope this helps.
MD
Old Jul 30, 2003 | 09:26 PM
CHCKLS's Avatar
Engine: 409 SR
Thanks.
Old Jul 31, 2003 | 03:29 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Don't match the driveshaft! I have posted this seveval times- maybe mods should post a sticky link or something.
Old Jul 31, 2003 | 03:30 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
part 2- different ride height examples.
Old Aug 1, 2003 | 07:15 AM
CHCKLS's Avatar
Engine: 409 SR
So if I read that correctly I have to remove the tail shaft off my tranny to get the correct angle from the out put shaft?
That might be easy to do with an automatic tranny, but it's not going to happen with a manual tranny, especially with the T-56.
Old Aug 1, 2003 | 09:51 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Look, its a basic example of what has to be gauged-HAS TO- no ands ifs or buts. What ever your method- the output shaft angle must be taken. Then with the car chassis at the same angle (with the rear axle loaded already) you the match the pinion angle to the outputshaft angle THEN drop the front of the pinion 1* more.
Use an extra yoke without the u-joints installed (drop a square from the u-joint mount angle and gauge underneath, Ect.- be creative- not my problem how you do it, but it NEEDS to be gauged.
Old Aug 1, 2003 | 10:15 AM
CHCKLS's Avatar
Engine: 409 SR
geeeez, no need to be touchy. Thanks for the info.
Old Aug 2, 2003 | 08:14 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Why is it that all the manufacturers installation sheets that I've seen say to reference the driveshaft if its so wrong?
Old Aug 2, 2003 | 01:50 PM
Racer3313's Avatar
Car: 1991 Camaro RS
Engine: 305 LO3
Hey, is there any way Spohn could jump in and clear up the confusion on setting the pinion angle? Do you use the drive shaft angle as reference or not?
Thanks,
MD
Old Aug 2, 2003 | 05:19 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
The front driveshaft to yoke angle and the rear driveshaft to yoke angles have to be as close to match as possible to cancel out harmonics. If they do not cancel eachothers angles then things will vibrabate and wear much faster (aka the waa-waa's)
Racer- I live 10 mins from Currie Enterprises, Craig (Sales rep at Currie) is a friend of mine- I have a large bearing HD Currie 9" in my truckwith a Detroit locker- great rearends.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
