Springs to get??
Old Jul 30, 2003 | 01:42 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Springs to get??
Anyone have a suggestion on which springs I should get? The Eibcah ones in JEGS are like $240 and there is a set from Suspension Techniques which is like $170. Both kits lower the car 1". Any body have an opinion?
Old Jul 30, 2003 | 04:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's my car, "before" with 250,000+ mile springs, and "after" with the suspension techniques springs: 1 inch drop, #60115 (for 2.8/3.1 82-92 v6 f-bodies), from http://www.shox.com . The springs look like they are a linear rate; each coil was spaced evenly.
<IMG SRC="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=1371861">
Oh and if that's the Pro Kit you're looking at, shox.com has them for $229.
Old Aug 1, 2003 | 06:53 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
I'll go with the ProKit,, I got the suspension technique springs on my car now and it dropped it 2 inch and I needed to installed rubbers springs stabilizer so it would not bottom out. I'm not happy with them so spend an extra 50 bucks and go with the Prokit if your car is a everyday driving car. I understand the Prokit will only drop about 1 inch. (this always depends on how old and worn out your current springs are). Good luck.
Old Aug 1, 2003 | 07:07 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Did you use the stock bump stops or is there an after market source for lowered cars.
Old Aug 1, 2003 | 07:25 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Stock,, they recommend to cut them off about 1/2 inch but I did not because I'm going to buy the prokit soon.
Old Aug 1, 2003 | 10:27 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Damn Tony, those rims look hot on your car!!
I got two bump stops with my SST springs, but forgot to install them The back tire does ride awfully close to the rear wheel well lip, though- but so far, no damage! (I'm more worried about quarter panel damage then tire damage)
Old Aug 2, 2003 | 09:08 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Thanks,, I use to have Cragers but got tired of them, here is a picture I took today after its bath...
Old Aug 2, 2003 | 01:09 PM
1mean99grandam's Avatar
Those rims are hot! Where'd you get them from? Not that I'd copy you, but I am looking for some nice aftermarket rims right now. Also, anyone know where to find billet accessories for third gens? I can't find any.
Good luck on the springs. I need stiffer springs all the way around. Mine are too soft.
Old Aug 2, 2003 | 11:08 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
These are Centerline "Tornados" 17x8 with BF Goodridge Scorcher TA 245-45/17. I bought them thru the centerline website. They were on sale for $108 each.
Old Aug 3, 2003 | 04:33 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Pro Kit...try the classifieds. I see a set every now and then and usually for around $150-200 shipped. I got mine new for $210 shipped from the classifieds.
Ed
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
