4th gen rack & pinion?
Old May 28, 2003 | 10:13 PM
Kandied91z's Avatar
anyone running one?
Old May 29, 2003 | 09:37 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I sold my 4th gen setup to drain89 and he is working on getting it mounted in his car.
Old May 29, 2003 | 10:56 AM
MikeTTA89's Avatar
What did you have to do to make that work?
Old May 29, 2003 | 11:06 AM
355SS's Avatar
Car: 90 Camaro
I had to make a mounting bracket and attach it to the k-member, make a new steerng shaft, shorten the steering arm on the spindle. I found hoses that worked with the stock ps pump and the 4th gen rack. I drove the car once with the fourth gen rack and was not happy with my bracket so I was redesigning it. But after may car had been sitting for 6 months my wife reorganizeds my priorities and I desided to sell all of my parts. I kept the mounting bracket for liability reasons. Maybe Dwain will give us a update on his progress?
Old May 30, 2003 | 06:43 AM
Kenn's Avatar
355SS - How did you shorten the steering arm on the spindle? - I'm gettin ready to switch to a fourth gen rack and was thinking of shortening the steering arm to get quicker steering and change the Ackerman angle - but looking at the thickness of that arm it seemed like cutting a section out and re-welding it wouldn''t be strong enough
Nice Brakes BTW
Old May 30, 2003 | 06:57 AM
355SS's Avatar
Car: 90 Camaro
I made a temporary bracket that bolted to the stock arm and moved the tierod bolt point closer to the centerline of the spindle. I was going to change it so my other two options were cut and weld or make a new bracket that bolts to the back of the spindle.
Old Jul 7, 2003 | 11:12 PM
mud
Guest
Posts: n/a
I haven't installed it yet since I'm waiting on steve spohn to release his street version of a tubular crossmember which will have provisions for the 4th gen rack as an option.
Old Jul 9, 2003 | 09:26 PM
Rage13's Avatar
Car: 89 Firebird
maybe you could drill a hole farther down the arm rather then cutting it?
Old Jul 15, 2003 | 04:52 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Does anyone have any pics of this? I am contimplating doing this so I can mount a vortec sc on my lt1.
Kory
Old Jul 15, 2003 | 06:27 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Kory
Try the powerdyne impala kit, theres also an ati kit floating around for them, and also the possibility of going to vette accessories and the vette vortech bracket.
Terrell351
Jun 13, 2021 01:13 PM
cam-mike
Aug 24, 2015 07:23 AM
overdriv
Aug 20, 2015 03:52 PM
