Rack & Pinion for an 84Z28
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
My neighbor wants to give me a Power Rack and Pinion stering set-up out of his 94 Camaro. It is 57" end to end and 34" from left. Can I install this rack and pinion in my 84 Z-28 without allot of alteration?? Thanks, Ed.
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Originally posted by Xceleratemaro
NO...no one has gotten a 4th gen rack to work ...sorry..
I intend to engineer a piece that bolts or welds behind where the sway bar is located (basically where the pitman and idler arm ends are). The 4th gen rack and pinion unit will bolt to it. All I know is that by spring I will have it ready to do since I have a list of mods to prepare by then before reinstalling the engine.So YES, it can be done, but NO, not without quite a bit of modification.
Here's a pic of the equipment I will be using from a Z28 Camaro;
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Originally posted by tpiroc
Should have put "yet" in that statement
Car: 92 Z28
Engine: Boosted LSX
Your not the only one thinking about it. Ive been debating on to adapt one out of my 94Z parts car. Only Im useing a Pro fab tubular k member and a-arms also..
Its crossed my mind to look into useing the complete front section kinda like FATAL88 did...
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
So what are the challenges? Does this require replacement of the entire steering system (column and ps pump)?
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
It has been done and the biggest problem is that the 4th gen rack does not have as much throw as the 3rd gen steering so you need to shorten the steering arms on the spindles
thanks chris
Car: 90 Camaro
Car: 90 Camaro
The option that I choose was to have a custom rack built to my specs and then I fabricated all of the additional parts needed to install it.
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
I think the late 3rd Gen steering boxes are excellent, so assuming it's not ragged out, it shouldn't give up anything to a r&p system...would it really be worth all the trouble to convert it into a 3rd Gen chassis?
I've got two 1999 4th Gens, and I don't think the steering set-up is any better in either the Z28 or the WS6 than what I had in my old '83 Z28 or '90 RS.....
Car: `86 SS / `87 SS
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
The strut mounts on the mustang spindles are so close to a third gen it`s scary, The bolt pattern is the same but the width of the spindle mount are completely different. The mustang strut should fit in the strut mount of the camaro, the difference between the two are length, the mustang strut is longer which could cause some problems with a lowered stance. The location of the mounting pins that hold the rack should be the only "true" fab work
dimented24x7
Sep 17, 2015 06:58 AM
