Fuel rail o-rings
Old Sep 8, 2005 | 11:35 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Fuel rail o-rings
I'm going to be replacing the fuel injectors and have found that there are at least 3 o rings connected to the fuel rail. The first is on the pipe connecting the 2 halves of the fuel rail, near the fuel pressure regulator. The other 2 are on the fuel lines you disconnect at the front of the engine to free the rail to be removed. Can anyone tell me the exact sizes of all these o rings or what kit I should buy that has a large variety of rings to choose from(and really, how to determine the size so I don't use one too small or too big)
Old Sep 9, 2005 | 12:25 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The front and rear crossover tubes use different size o-rings. Try a GP Sorenson 8009211 kit.
The o-rings on the feed/return lines are easily available through your local parts store too. GM parts # are 22514722 and 22516256. Borg-Warner 27478 or Niehoff 27478 are cross-references.
HTH
Old Sep 9, 2005 | 02:50 AM
Elthesh's Avatar
Thank you VERY much for those part numbers. By the looks of it, I'll need to order them off one of the sites. They're not showing up as available at the local stores, just through the mail. Perfect though, so much better than guessing at the correct ones.
Old Sep 9, 2005 | 08:37 AM
Jade Grey's Avatar
Engine: 305TPI
I'd try Advanced Auto or NAPA.
Old Sep 9, 2005 | 04:33 PM
Elthesh's Avatar
You've been very helpful, thanks very much. I'll give those places a shot and then call other stores and a few dealers before I have to order.
I have one last question. I've noticed that the v6 engines have an o-ring on the distributor shaft. Do the v8s have this too? If so, any idea which one I need?
Old Sep 9, 2005 | 05:48 PM
Jade Grey's Avatar
Engine: 305TPI
Yes there is a mounting gasket on the distributor. Fel-Pro 70194.
Old Sep 9, 2005 | 06:41 PM
Elthesh's Avatar
Yeah, that I have already. The new one happen to be blue. Hmmm, I mean... A rubber o-ring on the distributor shaft itself. Like, it'd be inside the engine/intake before I pulled the shaft out. The gasket sits on the intake between the bottom of the distributor and the intake. The o-ring I mean would be on the shaft, if there is one. I don't see mention of one anywhere, but I'd rather be safe than sorry later on.
So essentially what I'm asking is, I know there is at least one gasket for the distributor to seal it to the intake(material/paperish type). Is there a second(rubber o-ring type) on the shaft that goes in the intake/engine?
Old Sep 10, 2005 | 12:52 AM
Brian'sIROC's Avatar
GM part number for the complete fuel rail o-ring kit is 17111696. This contains all the necessary o-rings for the crossover tubes/regulator.
Old Sep 10, 2005 | 10:07 AM
Jade Grey's Avatar
Engine: 305TPI
I would have given him that part number, but he was also concerned about send/return fuel line o-rings that are sold separately, not in the fuel rail kit.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
