Factory 9.5" ring gear????
Old Oct 14, 2000 | 10:24 PM
theblooms's Avatar
I just got a 1984 Camaro F41 as a parts car and when I ran the RPO's I came up with this:
Y06 : Ring Gear, 9.50 IN., Saginaw, (S.P. 0.)
What is going on??? Did I strike gold or something??? What exactaly is does this option mean?
Thanks in advance,
Michael
Old Oct 15, 2000 | 09:23 AM
ede's Avatar
ede
don't know for sure about the f41, but you should have a 7.5 or 7.62 ring gears. the old style 10 bolts were 8.5 and there were a few 8.2. dana makes a 9.75 ring gear and ford has the 9 inch. i'd guess it's a typo or something of that nature.
-=ICON MOTORSPORTS=-
Old Oct 15, 2000 | 11:28 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I doubt that option is in the car. A 9 1/2" ring gear is the small 14 bolt diff. It was available in 90-93 454SS trucks. The large 14 bolt diffs are 10 1/2" and come in 3/4 and 1 ton trucks.
Climb under the car and count the bolts on the diff cover.
I have no idea what a F41 car is.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 18, 2000 | 07:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Drum brakes? Those are 9.50" ...
The ring gear is the 7½" like every other 84. I've seen quite a few cars from around that year with the "F41" badging, they were usually 2.8 cars, occasionally MPFI. I don't think it was the same thing as the RPO code for the suspension.
Old Oct 18, 2000 | 08:22 PM
theblooms's Avatar
Well, this car has the L4G 305 with heavy duty cooling. It has a factory optioned oil cooler. It also has the RPO code F41 and when I looked under ther car, there were thick anti-roll bars! Cool! The engine threw a rod through the side of the pan, but I got the car for parts for my 85 anyway. I am gonna pull the fan shroud, oil cooler, A/C lines, and anti-roll bars. I may pull the seats too, cause they are in good shape.
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
