Rodends-when quality matters
Old Jan 19, 2005 | 01:02 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
A personal revue of rodend quality and very hard usage- I abuse my cars daily so the best matters to me. These last ones were a little difficult to come by but an acquantance was generous to help me acquire them- Thank you to that person.
I have new lightweight Moser alloy axles (flanges drilled to reduce rotation mass) coming by the end of next week. The new rodends will go on at the same time. I have one of the Aurora's that has started to knock.
Old Jan 19, 2005 | 08:50 PM
Rage13's Avatar
Car: 89 Firebird
info noted for later use. thank you
you wouldn't happen to have a quick v6 camaro would you? different name maybe?
Old Jan 19, 2005 | 10:08 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Yes I am Vsixtoy, agood2.8........ and few others
Old Jan 20, 2005 | 11:56 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
What is the price on those pieces?
Why are they hard to come by?
Old Jan 21, 2005 | 12:06 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I got two of them for $109 the pair. The sale for much more retail from what I have been told. I paid just shy of $100ea for the Arora's in the picture above.
They are special order only, nobody I checked with stocked them or would bother getting them for me. (Summit, and a few other local QA1 suppliers)
Old Jan 21, 2005 | 12:17 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Rodends-when quality matters
What would you estimate your monthly mileage is?
Old Jan 21, 2005 | 12:24 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
37,000 miles on the new 2.8 in 3 1/2 years so about 1,000 miles per month basically.
Wife drives about 800-900 of that and I beat the sh*t out of it the aprox 100-200miles per month I drive it when I am alone in it.
This car pulls over 1 g and I get on it hard anytime I have free road without other cars around ( I try not to drive like an *** around other cars- takes one unperdicted lane change by someone into me an I'm in prison for life at the speeds I would be buzzing them- I thow it around always when unabated.
Old Jan 21, 2005 | 12:35 AM
So the Q1As only lasted a few thousand miles?! Thats terrible. Do you use any type of lube on them like graphite (looks like 1 may be greased by the fitting)?
You must be behind the wheel.
Old Jan 21, 2005 | 06:09 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I wonder how the XMR series would work in your app..
Kat
Old Jan 21, 2005 | 06:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Hum, is this the info I belive it is?
Old Jan 21, 2005 | 07:01 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Justin, I lubed the PCMR zerks with Mobil1 Synthetic grease
Kat, The QA1 XMR12's are a load rating of 28,081. The XMR12-14 has the larger 55,692 rating but has a 7/8-14 threaded end and not the 3/4-16 end we need. Ps- I thought youmight have seen these already-hint
Jay(dale),???- get some sleep, that tranny swap is getting to you.
Old Jan 21, 2005 | 08:36 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
why do you go by so many names?
Old Jan 21, 2005 | 09:00 PM
EvilCartman's Avatar
Car: '82 Z28
Some mod(s) has/have an itchy trigger finger on the ban button.
Old Jan 22, 2005 | 01:17 AM
Lets keep this thread on topic guys!
I think thats what on my car now, the PCMR. I got it from Spohn 2 years ago. I got a XMR but haven't put it on yet. I put about 600mi/month for comparison. Potholes, pavement trenches and all. Starting to get a knock knock out of it.
Old Jan 22, 2005 | 02:56 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Actually I didn't get a chance to see them. I was busy doing other stuff when they were shipped
I rememeber reading QA1's catalog about them. They are strong! Reason why I said the XMR moslty cause they are teflon lined and wont wear out and they aren't as expensive as the ones you got.
Then again I dont drive my car no where near as hard as you do too. lol
[edit] looked at the catolog again.. Didn;t know you can get them teflon lined too!
Kat
Old Jan 22, 2005 | 06:25 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Kat
Yep, I did get the teflon line ones.
The Aurora's on the car now are also teflon lined- hence the "T" in the PRM-12T. They are very good. I have one that is still perfect and the other is slightly knocking. Itf I turn the one that is knocking just slightly cocked to the left or right then the knocking stops, but I am just buying a little more time til it comes back. i don't have massive HP on this car but I do corner and brake very hard so the weight transition is very aburt on them.
Old May 17, 2005 | 12:55 AM
83 Crossfire TA's Avatar
Ok, now I’m curious what my spohn parts came with, since they’ve got about 20K miles and about 3 years of actual weather (as in even some salt on the roads) and they aren’t making any noises that I’ve noticed.
Old May 17, 2005 | 04:56 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
If you look at them you can see two black spots on the the one side of the bearing, you got the XM Series. Which are the teflon lined ones that he has been using for a while. Thats about the easiest way to tell.
Also if you look at Dean's pic, the top left pic, the one that is to the left is a close enough one to what we use all the time. The one on the right is a greaseable steel one. Those are the style that wear out quickly.
Kat
ZEEYAA
Apr 16, 2023 08:29 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
racereese
Oct 3, 2015 03:46 PM
