Roll Cage.
Old May 15, 2003 | 10:41 AM
89LT1Formula's Avatar
Roll Cage.
Anyone got any pics of an 8 point cage in their car on here. If you do could you send me a couple.. Installing a cage this week and just need some ideas on best location and what not. I don't have my Kirkey seat yet so i'm gonna wing it without the seat for now. I'll make the adjustments to the seat. Just wanted to get a general idea on where and how some have installed them. Perferable a weld in but bolt in will be fine too.. TIA
Old May 15, 2003 | 10:58 AM
I did a search on body and interior and chassis... but most of the pics don't show shots of where they mounted their main hoop. Anyone got a couple pics of that? Thanks
Old May 15, 2003 | 12:10 PM
MikeTTA89's Avatar
Why an 8 Point?
I am having a 5 Point made this summer. You planning on running sub 10s?
Make sure you read the rule book, 80% of the bars and cages that are sold are NOT NHRA/IHRA legal.
Old May 15, 2003 | 01:23 PM
My cage is a Jegs 10 point and I'm gonna be hittin 10's this year. The cage is NHRA/IHRA approved to under 9.5's. So i'm not too worried about it. Why are you only doing a 5 point??
Old May 16, 2003 | 12:16 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
heres the best one i've got
mike
Old May 16, 2003 | 08:51 AM
That's a good shot Mike.. thanks.. That's pretty much where I was plannin on puttin mine at as well. Did you put the 6X6 plates under at the points to stay legal?
Old May 16, 2003 | 03:14 PM
bjm323's Avatar
Car: '91 Camaro RS
Keep this in mind, In order for it to be legal, your helmet must be no farther than 6" away from the Main Hoop. Also, the top of your helmet must be at least 3" below the top of the Main Hoop. Just thought you would like to know this.
Old May 16, 2003 | 04:06 PM
I know the rules and regs for NHRA legal cages. I know the whole Helmit to bar clearance and what not. I just wanted to see some installs.. The whole helmit clearance is gonna be an issue for me anyways but the seat will take care of that. I'm 6'4". lol
Old May 19, 2003 | 08:14 AM
MikeTTA89's Avatar
1. Its a Street car, No jungle gym for me.
2. Its Lighter, no need for extra weight.
3. Less cutting up the car to install all the extra points, that are not needed in the first place.
4. 10.00 still needs a 5 point cage to be legal, its only till you roll past 9.99 that you need to upgrade. A good 5 point cage will provide the protection you need in a roll over.
I notice that the cage above is being welded in place, I think in order for that to be legal you need to have reinforcing under the floor. Subframe cars are supposed to have Bolt-in rollbars unless its reinforced with a plate under it. I'll have to go grab a rule book.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
