Anyone know what a rotary engine is??
Old Jul 21, 2002 | 04:40 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
Can someone explain what this is, and how it works.
Old Jul 21, 2002 | 04:53 AM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
http://www.howstuffworks.com/rotary-engine.htm
Old Jul 21, 2002 | 05:15 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Lol, Rx7speed, I hear your name being called...
Old Jul 21, 2002 | 05:34 AM
ede's Avatar
ede
when i read it i was thinking radial engines, i never could quite figure them out, but all i've seen is the outsides of one.
Old Jul 21, 2002 | 05:58 AM
jfox55's Avatar
WHERE IS RX7!!!!!!!!!!!!!!!!!!!!! SOMONE MUST NOTIFY HIM.
Old Jul 21, 2002 | 10:03 AM
Vader's Avatar
Ede,
The next time you're in the area, drop in. We'll make a little trip and I'll show you the inner workings of a 7-cylinder radial. They're really a beautifully simple design. Their downfall is that they require a lot of space in a direction perpendicular to the crankshaft.
Other Radial "Oddities" -
There are no connecting rod bearings;
There is only one crankshaft throw;
There is no camshaft, only four lobes on the crankshaft;
Radials that aren't mounted flat (like those in a tank or amphibious vehicle) must be rotated slowly by hand before starting in order to work the oil accumulations out of the lower cylinders;
Almost all radials use a dry sump type lubrication system;
Contrary to common beliefs, not all radials are air cooled;
Most good radials use roller bearings;
Most radials I've seen use a single carburetor (the ONLY good Holley carb, IMHO - oddly very much like the Dominator but upside-down and a lot larger);
A Harley Davidson 'V' engine is very much like 2/5 or a radial engine;
Radials don't always have an odd number of cylinders;
There are diesel radial engines.
Just thought you might be interested...
Old Jul 21, 2002 | 02:05 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I still like the R2800's in all the old warbirds (2800 is the displacement in cubic inches) but the quad bank 36 cylender 4 staged supercharger 4000Hp@ 3600rpm R5600 in the F2G Corsair (goodyear's version of the Chance-Vought F4U Corsair) was the most impresive radial I can think of.
Old Jul 21, 2002 | 02:41 PM
jeffs82z28's Avatar
:hail: :hail: :hail: :hail: F4U Corsair :hail: :hail: :hail:
Old Jul 21, 2002 | 05:11 PM
IROCracer's Avatar
I remember a nice little flaming post concerning rotary engines a while back, think I mighta started the bastard.
Once again....me high, typing take too long.
Kelly
Old Jul 21, 2002 | 06:24 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
i believe i have seen on the discovery wings channel, that back in the day of radial engines, some of them actually rotated the cylinders and kept the crank shaft stationary, then the prop was connected to the cylinders somehow.
can anybody verify this?
Old Jul 21, 2002 | 07:30 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I've heard of the stationary crank radial engines, but never seen one.
R5600 huh?
Uhhh, I think it's YOUR turn to change the spark plugs. All 72 of them!!
Oh yeah, could you adj the valves while your at it?!?! Thx!!
hehehe
In A&P school, we had a DeHaviland Beaver with a R985. We got to tinker with it quite a bit.
It would smoke like crazy when first started, but it always fired right up, unless the instructor put a bug in it.
I remember it had an inertial starter. Inside it, there was a really heavy (~80 lbs) flywheel that could be spun up via hand crank if elec power wasn't avaliable. (Kinda sounded like an air raid siren) Once you got it spinning good, just engage the starter clutch and she'd cough,smoke, sputter a little, then smooth out.
It wasn't a high performance eng by any means, but it was still pretty cool!
Old Jul 25, 2002 | 07:22 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you mean ther is a guy on this site who knows something about them?
Old Jul 25, 2002 | 07:24 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
one question I have is how did this go from rotary motors to radial's?
Old Jul 25, 2002 | 07:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yes I know I am whoring a little but hey we all have our little ******
but take a look at my avatar and the pic in my sig
that kinda explains it a little
give me some time I will post some more
just kinda tired and cold right now
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
NOt sure.
Old Jul 25, 2002 | 07:27 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
oh yeah I'm a post *****
Old Jul 25, 2002 | 07:28 PM
Nate2's Avatar
Rotary engines and radial engines are two very different things people...
Old Jul 25, 2002 | 07:47 PM
jfox55's Avatar
NO WAY RX7, MARK IS THE BIGGEST POST ***** AROUND!!LOL!!!
Old Jul 25, 2002 | 08:05 PM
Car: 99 Formula
Axle/Gears: 342
Yeah right, did you see the other post he dug up and responded to like 10 times in a row.
Old Jul 25, 2002 | 08:09 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Kelly
yeah I just covered that one really well
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hehe I would of had 21 post in a row if it was not for you mark
https://www.thirdgen.org/techbb2/sho...&highlight=rx7
Old Jul 25, 2002 | 08:10 PM
jfox55's Avatar
HOLD ON!!!! LETS LOOK AT THE SCORE HERE!!
MARK SHIELDS RX7
7730 :lala: 1343
HMMM, WHAT WAS THAT YOU WERE SAYIN MARK LOL!!!
Old Jul 25, 2002 | 08:11 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yeah but that doesn't tell the whole story
I haven't had all the time to spend on this thread like he has
I don't have a computer
Car: 99 Formula
Axle/Gears: 342
Sorry I didn't mean to rain on your parade, I thought you were done posting on it. Then I recheck it and there are like 5 replies after I replied.
Old Jul 25, 2002 | 08:13 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hey man don't worry
I will dig up some more threads that should be dead and post on them soon
when your gone though
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
