preping car for storage
Old Jul 29, 2004 | 07:20 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I just got orders to Kunsan AFB ROK , my departure date is 31 Oct 2004, I will be putting my car in base storage. I need to put a checklist togeather of stuff I need to do to it, any ideas, by the way I have an optima battery, will that be still good after sitting for a year? also there has been a recent slew of break-ins in the bace storage area, other than insurance, anybody have suggestons on keeping my car safe? thanks in advance
Old Jul 29, 2004 | 09:44 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Unhooking battery cable will help the battery keep charge. So will storing it someplace cold. Use a fuel saver in the gas tank. Change at least the oil but it wouldnt hurt to change all fluids before you leave and when you get back. Put the car on stands so you dont flat spot the tires. I dont think youll need anything to keep rats or moisture away there in NV but those can also be a concern.
As far as protection from a break in, i would remove the things that are usually or easily stolen, rims, stereo, etc. Removing the battery would make it much harder to steal the car as the theif would need a tow truck or his own battery.
Old Jul 29, 2004 | 09:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Change the oil (used oil has acids that attack bearings); fill it with gas, add a can of fuel stabilizer; store it on jack stands with the tires off the ground, and put on a set of wheel locks so the wheels don't roll away by themselves; disconnect the negative battery cable.
Old Jul 29, 2004 | 11:54 AM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
i also put the car on jack stands/blocks...so that the tires don't get flat spots form sitting
Old Jul 29, 2004 | 04:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Not all tires will flat spot. It is a good idea but put the stands so that the suspension is loaded. My car has sat for over 1.5 years a time and the flat spots always went away after a few miles of driving. Not all tires will though but the two sets I stored my car on over the years didn't not. Newer tires re-bound very well nowadays.
EDIT: Like RB said, fill your tank up and put some stabilizer in it. Also, put a few sheets of bounce fabric softener in your car to keep rodetns out. It sounds goofy but it works and it has been shown from various lab testing that rodetns detest the smell of bounce. I had rodent problmes one year, added bounce and all is fine numerous years later.
Old Jul 29, 2004 | 04:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I second the notion of doing what you can to keep rodents out. I had a mouse die in my blower motor box
Old Jul 29, 2004 | 06:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Vader had a very thorough checklist posted, probably numerous times.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
NBrehm
Aug 5, 2015 07:57 PM
