Need Recommendation on new upper strut mounts
Old Nov 30, 2003 | 11:22 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Who all has changed these out, and what did you use?
Is there different brands?
What do they cost?
Where did you buy them?
I am in the middle of my suspention rebuild,( New struts,
springs, sway bars ), and after taking the struts out,
I find that one of the bearings is shot, so I want to
replace both while I've got it tore down this far.
Thanks for any suggestions you may have
Old Nov 30, 2003 | 11:44 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
spohn sells moog and some other fancy brand
Old Dec 1, 2003 | 12:14 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Ground Control Caster/Camber adj plates.
They increase your travel on lowered cars and re-use your sheetmetal upper strut mount housings, but eliminate the rubber biscuit and you get more adjustability.
http://www.ground-control.com/?D=72f...7607aca9045a31
Also, Spohn is now selling sweet billet upper mounts, but they're not cheap.:
http://www.spohn.net/category.cfm?categoryid=1071
-Rich-
Old Dec 1, 2003 | 12:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for info that may help:
https://www.thirdgen.org/techbb2/sho...hreadid=183622
JamesC
Old Dec 2, 2003 | 10:00 PM
iroctpis's Avatar
alloy specialties
Here are the alloy specialties strut mounts and I repainted my jamex stb brackets. The mounts are great! solved my front end shake on highway.
Old Dec 3, 2003 | 06:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes, the spohn/alloy mounts are TOP notch. if have the extra money to get them, they are very well worth it.
Old Dec 3, 2003 | 07:48 AM
iroctpis's Avatar
bearing plates
When I replaced mine, I had to grind the old bearing plate nuts off because they wouldn't back out. I got some more of the bearing plates at the yard for $10. I also used an impact for the middle strut nut. Once all is unbolted they lifted right off and the struts traveled up since nothing was holding them on the top anymore. When I put the new ones on I could push the strut right down, then I just put the nuts back on. I was amazed that the struts were so easy to push down, I guess they are supposed to be sinced mine are tpis and they aren't but a couple years old
Old Dec 3, 2003 | 07:55 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Re: bearing plates
that is fairly normal. the strut is only there for dampening, and the forced needed to dampen are much higher on the rebound side, than the compresion side. you can very easily push it down slowly, but try to push it down very fast think about how fast the spring is moving when you hit a bump at 70mph. its purpose is to control the spring, not act as a spring.
Old Dec 3, 2003 | 08:09 AM
iroctpis's Avatar
That makes sense
Thanks for the info, oneday I want to try billstien shocks and struts, the tpis are way to rough with eibachs
Old Dec 3, 2003 | 07:57 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: alloy specialties
I'm very glad you are pleased with the mounts, and that they cured the problem with your front end.
Old Dec 4, 2003 | 09:31 AM
iroctpis's Avatar
good service
thanks, great service and very nice mounts!
Old Dec 4, 2003 | 12:11 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
When I bought my KYB struts and installed them I noticed the factory nut that attaches the strut to the plate had a camfer on it's bottom to positively locate it but the KYB had a flat nut that allowed some movement in the mount. Anyone else had a similar experience with aftermarket struts? Did any of the aftermarket plates come with strut hardware, or are they tighter around the top of the strut bolt?
Old Dec 4, 2003 | 12:32 PM
alloy's Avatar
Car: 87 IROC-Z28
The mounts I manufacture have machined reducer bushings pressed into the bearings to make it a snug fit on the top of the stut. Not sure about other aftermarket mounts though.
Old Dec 4, 2003 | 03:27 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
How much are those alloy beaut's??
Old Dec 4, 2003 | 03:30 PM
Dewey316's Avatar
Car: 1990 Camaro RS
http://www.spohn.net/product.cfm?productid=1452
Old Dec 4, 2003 | 09:33 PM
1tinindian's Avatar
Thanks for all the high dollar input, but I'm looking for your basic replacement parts!
Unlike the rest of you replying on this subject,I don't have $350.00+ to get my struts back in.
Is there a preferred brand under a $100.00 each, that people are using, or is everyone here into the high dollar stuff?
Don't get me wrong, I think the alloy pieces look super, just a little out of my budget at this time
Old Dec 4, 2003 | 09:37 PM
iroctpis's Avatar
Sure there are cheaper ones, the stock ones. Spohn sells them here for $164 for the pair, I think they are moog
http://www.spohn.net/product.cfm?productid=1375
Old Dec 5, 2003 | 10:15 PM
laiky's Avatar
i think monroe makes them too for about 55 bucks each
Old Dec 6, 2003 | 10:17 AM
1tinindian's Avatar
Thanks laiky,
Now we're talking in dollars I can relate too
Old Dec 7, 2003 | 01:40 PM
grafx's Avatar
Car: 91 Camaro RS
Transmission: Pro-Built Automatic/Vigilante 2800
KYB plates can be found for around $75 bucks each. This is what I have on my 91'
Old Dec 7, 2003 | 03:49 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
-Rich-
Rich - do you have their upper stress bars too? I'm wondering exactly what those are?? Are they the common strut braces you see or are they something to strengthen the tower top itself...
Old Dec 7, 2003 | 06:38 PM
Car: 92 Camaro RS
Yes, I have their upper stress bar as well. It's just a 2 point strut tower brace (tower to tower), but it clears carb or tbi air cleaners.
-Rich-
Old Dec 7, 2003 | 08:20 PM
JamesC's Avatar
Rich,
Got a pic of the stress bar? I couldn't find pictures on the web site.
JamesC
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
rb85TA
26
Sep 14, 2015 10:29 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
