Front suspension rebuild. What tools do i need?
Old Feb 17, 2003 | 03:21 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Ok, I have some new struts and shocks already installed. I want to replace my springs with some which won't lower my IROC too
much. While im there, I figure I might as well rebuild everything.
I want to replace my whole steering setup, meaning the pitman arm, idle arm, centerlink, tie rods, ball joints, etc. Spohn sells a moog replacement kit, so this would be perfect.
I was wondering, I know I would need a balljoint compressor to get the old balljoints out, and the new ones in, but could I
uninstall/install the rest of the parts with normal tools?
Or would this require a bunch of improvised tools, or specific tools to get everything off?
Thanks for any suggestions or comments!
Old Feb 17, 2003 | 04:58 PM
ede's Avatar
ede
ball joint press, pickle forks, coil spring compressor, and common hand tools is about it. i like to whack the parts that are going in the trash (sway bar bushings, ball joint nuts/studs, tie rod ends, shocks) with a torch instead of wrenching them off since it's lot faster and lot less work. look in your manual and you should see pics of what tools and their application.
Old Feb 18, 2003 | 07:21 AM
ebmiller88's Avatar
Internal coil spring compressor (Auto Zone), 24mm big socket, 21mm socket, pickle fork....What Ede said.
Click the link in my sig to see what you are getting into.
Ed
Old Feb 18, 2003 | 11:54 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
you dont need a spring compressor, at least i dont think so.
Old Feb 18, 2003 | 11:57 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I got my stock springs out without a compressor. Getting the lowering springs in during re-assembly....... I know I couldn't have done it correctly without a spring compressor.
Even then it was tough.
Best-
S-D
Old Feb 18, 2003 | 12:34 PM
ebmiller88's Avatar
OK, you don't NEED a compressor. I used one and it was easy to use so I used it, and I didn't have to fight with the springs or possibly have an accident. Taking them out without one will be easier than putting them in without one.
To each his own...
Ed
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 25, 2015 07:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
