Convertible Tonuea Cover
Old Oct 30, 2003 | 09:34 PM
RicMon's Avatar
Car: 88 /89 Iroc's
I need some help with the Tonuea Cover on my 88 and 89 Convertible's
At about 80mph the tops blow up in the back and looking at them I see it may have some type of lock too hold down the top ( not mine ) think i need one can anyone post a pic of the underside of the Convertible Tonuea Cover so i can see what I am looking for
Thanks RicMon
Old Oct 31, 2003 | 10:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres a fat pin with a point on the end and a groove in it on the actual top
theres a hole in the tonnu cover that this pin goes into.
the tip of that pin goes into the hole and pushes a clip out of the way... the clip snaps into the grove.
that holds the top down.
otherwise, it lifts up at speed.
pop open your tonnu cover and have a look at the underside of it... you should see what i mean..
Old Oct 31, 2003 | 11:39 AM
RicMon's Avatar
Car: 88 /89 Iroc's
the clip is what i don't see
where can i get one from ? think i need two of them !
how does the clip release from the pin ?
i have the pin and the hole but no clips
Old Oct 31, 2003 | 12:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hmmm.
man i wish i could take some pics....
ok, i'll try to draw you what it looks like...
ok, it works like this:
shutting it.
the tops pin gets pushed into the hole, the pointed nose hits the clip and pushes it out of the way.
the clip catches the notch in the tops pin and holds it down.
opening it.
you pull the cable. that pulls the arm toward the cable..
there is a little nub on that circle that is connected to the arm. it pushes the clip outward and lets the top come up.
if you dont have all the pieces, dont worry, just get a big cotter pin that fits on the lock for now, and you just have to reach back there and pull the pin before the top releases...... that will hold it down until you can buy the release arm.
i hope this helps.
Old Oct 31, 2003 | 12:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
oh, when installing the pin, i kinda drew that wrong.
the flat side of the pin goes INTO the hole/tube the round side goes AROUND it
in the pic i have the flat going around it and the curve going into.
Old Oct 31, 2003 | 01:39 PM
RicMon's Avatar
Car: 88 /89 Iroc's
Cool
Thanks that helps alot
I found the amr (pin release) in the truck but no pin and no rod or cable going to the pull handle
Do you know of a company that sell these parts ?
BTW nice drewing
Old Oct 31, 2003 | 01:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Cool
BTW nice drewing
not off hand no..... search these boards though, i know thats been asked before....
if you already have the arm, greas the tube/rod, slide it all together, pop a clip on and you can just turn the arm like its a handle under there to release it until you get the cable and handle
if you already have the handle, you could just use regular bicycle cable to release it though...
its a pretty simple system, but after reading how it worked a million times, i literally had to see it myself before i went "oh yea... duuuh thats how it works"
Old Jan 19, 2004 | 10:03 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ttt
can someone move this to converibles?
Old Jan 19, 2004 | 12:41 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
