TV cable adjustment
Old Feb 24, 2001 | 12:02 AM
leatherneckm's Avatar
TV cable adjustment
Ok, I am putting a new 700R4 in an 88 camaro tomorrow, can anyone tell me the PROPER way to adjust the TV cable? I don't want to destroy this trans. :-)
Old Feb 24, 2001 | 08:33 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
TV Cable
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 24, 2001 | 11:20 AM
tranny doctor's Avatar
Have someone inside vehicle and give it full throttle while someone opens TV cable window tnen push back 1/8 inch then close cable window. Then drive for fine tuneing. On a 1-2 shift you must have a 2-1 downshift same as 2-3 upshift you must have a 3-2 downshift and so on. If you really want to make sure your TV is perfect run a line pressure test. Line at minimum TV @ 1000 RMP in park or neutral should be 65-75 PSI. At full trottle TV pressure should be 130-170 on some and 140-180 PSI. F.C. Racing Transmissions by the Tranny Doctor
Old Feb 24, 2001 | 11:21 AM
Have someone inside vehicle and give it full throttle while someone opens TV cable window then push back 1/8 inch then close cable window. Then drive for fine tuneing. On a 1-2 shift you must have a 2-1 downshift same as 2-3 upshift you must have a 3-2 downshift and so on. If you really want to make sure your TV is perfect run a line pressure test. Line at minimum TV @ 1000 RMP in park or neutral should be 65-75 PSI. At full trottle TV pressure should be 130-170 on some and 140-180 PSI on others. F.C. Racing Transmissions by the Tranny Doctor
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
