Outer T-top seal part#?
Old May 2, 2003 | 08:57 AM
jonarotz's Avatar
Car: 91 Z28
I have been looking everywhere for this, I need to see if I can get a part # for the outer "lip" seal on the t-tops. Its the one that hangs/overlaps the window glass. I tore mine off a couple years ago because the were tearing. I need a GM part#. Can you even buy just these or do you have to buy the whole kit?
Old May 2, 2003 | 12:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
10198352 10198353 (L & R)
You'll probably want both so both sides match because they are plastic now, not rubber.
Old May 2, 2003 | 02:55 PM
jonarotz's Avatar
Car: 91 Z28
Thanks Deadbird
Old May 2, 2003 | 03:04 PM
88txiroc's Avatar
Does anyone know what the price is on those parts? I need two new ones, as well.
Old May 2, 2003 | 03:21 PM
deadbird's Avatar
Engine: TPI 305/ v6
Not a problem jon.
88az.. $36.37 GM list... $21.47 GMPartsDirect. A bit pricey but, if you need them, what'cha gonna do ?
Old May 2, 2003 | 10:43 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Those pieces are plastic now? How does that work? Anyone happen to have a picture of them? At least on my car, it seems like the glass kinda slides under it when you shut the door, how would that work with hard plastic? Or is it a soft kinda plastic?
I need a new set too...
Old May 2, 2003 | 10:54 PM
deadbird's Avatar
Engine: TPI 305/ v6
HG... to my knowledge (take it with a grain of salt ), GM revamped (I should say revised I guess..) the t-top seal designs in 92 upgrading the 'seal strip' (part in question) to plastic due to the problems with the rubber piece and the top seals got a 'rain channel' designed into the to help prevent water getting in betwen the top and roof joint. The 92 style is now the only seal available from GM.
Here is a shot of the door/glass just open past the seal strip...
Old May 2, 2003 | 10:55 PM
deadbird's Avatar
Engine: TPI 305/ v6
The glass passes just under the strip and when fully pressed against the jamb waetherstrip, the glass pushes upwards slightly making it appear as if the glas would hit it when the door opens but, is not the case... door fully shut...
Old May 2, 2003 | 11:17 PM
Hg's Avatar
Hg
Car: '87 Z
I see. Thanks man. So you sure those are the right part #'s? I need to get me a pair, my passenger one isn't bad, but my drivers side is about shot. It's ripped/torn in one spot...
Old May 2, 2003 | 11:27 PM
deadbird's Avatar
Engine: TPI 305/ v6
I'm 99% positive my case of stupidtitus didn't get me this time plus, I've yet to do my other t-top so the seal is still off it for me to check my #'s from the collision breakdown off my site. Hard too see (crappy camera) but, here is the seal strip # for the pass side...
Old May 3, 2003 | 06:27 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
What about the soft rubber seal that's on the T-Top? The piece that seals up against the inside of the window? Thats where mine is leaking.
Old May 3, 2003 | 02:38 PM
deadbird's Avatar
Engine: TPI 305/ v6
10165496 GM list: $37.14, GMPartsDirect: $21.91. Same number for both sides.
Old May 3, 2003 | 10:47 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
My 86 has rubber, my 92 has plastic. On the 92, the pass door used to shut on the plastic part in 1 spot and warped it. Later it ripped off.
Old May 15, 2003 | 10:52 AM
REDRIDER89125's Avatar
outer seals
I got my new ones over the summer, yes they aer plastic. I still havnt put them on b/c I dont know how to take the t-tops apert to get them on. As far as I got was removing the outer plate and latch handle thats it I dont want to break them so if anyone has any diagrams or something that will help i would really apperciate it. I wanted to get this done before I go to a meet in Toms River NJ to make it look nice.
Thank You
Old Jun 17, 2003 | 02:07 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i would also appreciate a diagram of how to take apart the t-top to change this piece
my driver side is warped and has a rip in it which makes it sag and when i close my door it catches the seal
Old Jun 17, 2003 | 04:16 PM
deadbird's Avatar
Engine: TPI 305/ v6
edit... http://www.deadbird.org/z/ttopawning.gif
Old Oct 18, 2009 | 05:58 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Outer T-top seal part#?
any updates?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
