Have idea for TT
Old May 8, 2001 | 01:50 AM
88birdformula's Avatar
Have idea for TT
I know the twin turbo has been posted to death, but heres something I haven't thought of till toaday... For headers, just get some shortys, flip 'em upside down, and weld a plate on the end to attach the turbo too. I don't know about VC clerance though. Do ya think it could work???
14X3 o.e., functional formula hood(for sale in future), uhhh..., umm...
Am I the only person who believes a car has feelings, emotions, and a soul??
Old May 8, 2001 | 07:21 AM
Blockhead's Avatar
Uh, that one has been suggested.
Jester is doing it.
Here is a Mustang (or capri I think) guy that did it as well.
EDIT on 8/2/04: Link no longer valid
91 Formula
Twin turbo
1156.4 rwhp
8.45 @ 171mph
Director of Darwin Awards @ www.thirdgen.org
Old May 8, 2001 | 09:59 AM
Bob Wooten's Avatar
blockhead, you have a web site with info on your setup? sorry if this is repetative, interested in the Turbo cars is all.
BW
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old May 8, 2001 | 10:33 AM
BLOWN85/TA's Avatar
I tried that once. They fit a little better than I expected but no where close to what I wanted so I gave up on that one. I thought that you could rework them and get closer to clearing everything, but if I had to do that I was going to build my own anyway. Hope you guys can make it work out!
Paxton NOVI supercharger W9Lb underdrive Combo pulley, 75HP N20 shot for charge air cooling, SVO 30Lb injectors, Accel AFPR & 300+ ignition, coil and wires, airfoil(getting T/B bored to 2.080" Sold BBK 52mm), ported MAF(waiting on 512gm.sec fix)Bosch Platinum plugs & O2 sensor
E-Tec200 heads ASM LTR & portmatched plennum, Crane Gold 1.6RR's & ZZ4 cam(small cam=streetable). Steel crank & rods, TRW blower pistons W/ZGS rings, all balanced, splayed main 94Vortec block, 1 5/8" long headers, SLP 3"catback minus the kitty!
Moser 9", 35 Spline Detroit Locker & Moser axle's 3:50 ratio HRW 3.250 case with Daytona pinion support, Strange Billet housing ends & 1350 Billet yoke wearing 94Formula disc's held in by all Lakewood adjustable components. HI-TQ GER 700trans,
2400stall with Cyberdyne fuel PSI and trans temp guages on pillar guage pod, 24,000GVW B&M cooler. Edelbrock strut tower brace. Working on converting to 89 chip & wiring.
Old May 8, 2001 | 10:57 AM
Blockhead's Avatar
No.
Old May 8, 2001 | 11:20 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Somebody here on this board has already done that Here's a hint ... its an ICON member.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old May 8, 2001 | 11:29 AM
BLOWN85/TA's Avatar
What headers did he use? I tried with some cheapy Headmen, I think. I would not be suprised if their is a set that fit good enough to do this. The Headmen were just not going to work for me, but I am one picky bastard to!
Old May 8, 2001 | 12:36 PM
Jester's Avatar
I'm using Heddman headers for an S10 with a v8 converstion. I decided it was a better idea to make an intermediate pipe to connect the turbos to the headers rather than weld a flange on the turbos...but you might be able to do it that way.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 8, 2001 | 01:34 PM
Bob Wooten's Avatar
have you got it running yet?
BW
Bob Wooten
71 Camaro, 91 EFI
Old May 8, 2001 | 01:43 PM
Jester's Avatar
Running yeah, not driving. I just did the first startup and break in a few days ago, has about an hour of running time on it total.
JSP Motorsports
ICON Motorsports
Old May 8, 2001 | 02:47 PM
Bob Wooten's Avatar
Cool, let us know when you stark spanking on it.
BW
curious why you chose to goto a carb instead of putting on a tpi or somethign that might be a bit more happy with the turbo's?
Bob Wooten
71 Camaro, 91 EFI
Old May 8, 2001 | 02:57 PM
Jester's Avatar
I converted to carb over a year ago because I couldn't stand fuel infection. Nothings really changed not to mention converting back would greatly increase the cost of the swap.
JSP Motorsports
ICON Motorsports
Old May 8, 2001 | 03:07 PM
Bob Wooten's Avatar
I gotcha! jus curious
BW
Bob Wooten
71 Camaro, 91 EFI
Old May 13, 2001 | 10:13 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Jester, how do you have it plumbed to push the air into the engine or is that part not in the pic? it looks awesome I bet once its broke in and tuned up right it will scare the hell outta ya , I recall driving a TT 300 ZX and you had to hang on just to hold the steering wheel and it was a V6.
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. So if anyone knows where a buick GN 8.5" rear is let me know.
Old May 14, 2001 | 12:09 AM
Jester's Avatar
Monte that part isn't in the pic. Actually it's not even built yet. It'll be really simple tho..just tubing from the turbos to a hat on the carb.
JSP Motorsports
ICON Motorsports
Old May 16, 2001 | 12:32 AM
monte-ss's Avatar
jester, I understand your system now but thought that carbs worked on vacuum not pressure? and the smaller pressure(compared to efi) wouldnt allow a forced induction through rather than like a blower which pulls through the carbs? Im sure youve done your research but please enlighten me.
thanks
Old May 16, 2001 | 01:47 AM
B430's Avatar
yeah that's what i was thinking too. only way i could think something like that would work is if you ran a line to pressurize the bowl of the carb to make it intake pressure so fuel is still drawn out of it rather than air pushed in.
sorry if what i'm saying makes me sound like an idiot, the only experience with carbs i have is on lawnmowers.
Old May 16, 2001 | 08:45 AM
Bob Wooten's Avatar
You can push through a carb (i am talking about your generic Holley, not sure about a Quadrabog) but unless you put the entire carb into a box, there is a modification that you have to make to the carb for it to work right.
BW
Bob Wooten
71 Camaro, 91 EFI
Old May 16, 2001 | 12:31 PM
Jester's Avatar
The fuel bowls get pressurized via the vent tubes anyway, you don't have to modify anything for that. You do have to boost reference the incoming fuel pressure somehow. The only other problem is a/f mix blowing out of the throttle shafts. EFI TB's do the same thing under boost, it's just not a serious problem because there is no fuel at that point. I've heard of people getting away with under 15psi without doing anything...but after that you have to seal or pressurize the throttle shafts. That takes some modifications. I'll be doing it myself..or the Carb Shop will do it for about $150
Old May 16, 2001 | 02:04 PM
B430's Avatar
this may be kind of a dumb question but can you explain to me why you decided to put the carb after the turbos rather than a suck through type? i can think of a cople reason why this would be better, but can you tell me why you did it?
Old May 16, 2001 | 02:27 PM
Bob Wooten's Avatar
I am taking a guess here but you cant intercool w/a draw through system. & if you are doing TT that means Twin Carb & that means Twin Pain.
BW
Bob Wooten
71 Camaro, 91 EFI
[This message has been edited by Bob Wooten (edited May 16, 2001).]
Old May 16, 2001 | 04:21 PM
Jester's Avatar
Draw throughs do have some definate advantages, and I've even seen twins drawing through one carb. But you can't run an intercooler, and actually doing the plumbing is alot harder. Plus..the turbos have to be mouted REAL close to the carb and intake...like over the valve covers, and I couldn't really plumb it that way
JSP Motorsports
ICON Motorsports
Old Jul 26, 2002 | 10:05 AM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
I was wondering if you were using something like this to mount it to your carb or what? http://store.summitracing.com/partdetail.asp?part=27012
Old Jul 26, 2002 | 10:37 AM
ATOMonkey's Avatar
Turbos don't like little drops a fuel hitting them at 100,000 RPM. Tends to beat things up.
Old Jul 27, 2002 | 01:05 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
the chiller
im an ID10T
Old Aug 2, 2004 | 01:53 PM
gmartin's Avatar
Car: monte carlo ss
Engine: l98
Transmission: 200r4
You can get one through g-body.com 410 287-4370 be however they are pretty costly at 850. I have a 86 ss and in the process of doing a l98 block. Is yours a 383 or 355. Also what do you think about a turbo set up vs a ati procharger on a monte cost wise.:hail:
Old Aug 3, 2004 | 12:40 PM
blownSS's Avatar
Engine: 383
Both myself and Biggtime have G-Body cars with ATI prochargers and they work great. They are both fuel injected. You can check them out here:
Monte Carlo SS
Cutlass 442
Old Aug 3, 2004 | 05:06 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
holy-back-from-the-dead batman!
Old Aug 3, 2004 | 07:58 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
who
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
