Underdrive pulley's
Car: 89 Camaro RS
Engine: 305 TBI LT-1 Cam/TBI Chip
Transmission: Automatic
Underdrive pulley's
I am looking to buy some underdrive pulleys for my 305 TBI. All the ones I have found are only for the TPI and 305/350 Truck. I know heads and exhaust amnifolds are swappable. So would the pulleys be also.
Car: 89 Camaro RS
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361 Which one of these would I get.
Car: 2002 Z28
www.aspracing.com
the crank pulley is the only one that is going to net you any power. Type the ASP part number into summitracing.com, i believe they sell them for cheaper
Car: 1991 Camaro RS
Engine: 4 bbl 305
i just went with the March two piece 88-92 pulley kit for my LO3.i picked up an honest tenth in the quarter mile.Only thing i dont like about them is the battery doesnt charge until 1500 rpm because it slows all your belt driven junk down
Car: 1991 Camaro RS
Engine: 4 bbl 305
yep the crank pulley is smaller than the water pump and the alternator pulley is just a tick maybe like a couple mm bigger than the stock one
Car: 2002 Z28
yeah, use the stock alternator pulley. First i installed my crank pulley and had no charging problems so i said, "what the hell, might as well install the alternator pulley", killed the alternator in about 4 months.
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Originally posted by PyRo9862
So you get an altenator with a lifetime warrenty and let it die every 4 months
My dad had pulleys on his Bronco for like, 2 years without a problem. Its how you drive the car. We drove it 90% highway. If you do alot of idling, then you might have a problem.
March does make a set that increases charging capacity.
Car: 89 Camaro RS
Here is a set will these suffice. Pulley set 88-92 camaro/Firebird 25% crank/23% alt full @950 rpm They are ASP-540801 on summitracing.com
bigjay89gta
Oct 15, 2015 08:04 AM
350, alternator, asp540801, chevy, crank, gains, junk, kit, lt1, pulley, summitracing, tbi, tpi, underdrive, worth
