VSS problems
Old May 14, 2002 | 07:09 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
VSS problems
Hello. Had a bit of a setback with my VSS. I changed it to a 43t driven gear from the 37 (IIRC) when i went from 2.73s to 3.23s. Now a few hundred miles after the speedo gear swap, my VSS shaft snapped.
At first that struck me as odd, and i did some digging and found an old post where a user mentioned different VSS's for different size speedo gears. His idea was that higher tooth count = bigger speedo gear = more offset to the shaft. Upon quick inspoection, the 37t driven gear is noticeably smaller. (see attached pic) I can easily believe that much extra offset would have side loaded and killed the VSS shaft.
Now, does anybody know what the correct VSS would be for a 43t driven gear (with a red drive gear if that matters?) If i go to the dealer and get a VSS for a 92 L98 should i be ok, or were they grey drive gears with small driven gears? Any ideas, this is the kind of problem that i know the guy behind the counter will look at me funny and act like i am an idiot cuz he won't understand it.
Old May 15, 2002 | 06:03 PM
Ed Maher's Avatar
Car: 04 GTO
Got the correct VSS today, GM PN #10456089
If i heard the guy right this is the VSS used on 41 tooth and larger driven gears, and it in fact has an offset shaft. If you're changing speedo gears from a 37t to a larger piece, you'll need this or you'll likely snap your VSS shaft like i did after a few hundred miles.
Old Apr 2, 2003 | 10:40 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Digging this one up from way back.... Have you ever heard of anyone else with the same problem you had? I'd rather not lay down 30 bucks for this sensor when I am already dishing out 40+ for the 2 gears (15T and 44T)
Old Apr 3, 2003 | 02:15 AM
hydra512's Avatar
well when i replaced my gears i kept the old VSS in there. it worked for maybe 2 weeks then all the sudden i had no spedometer. i thought the plug that went to it disconected. i checked that but it was still in place so i took the VSS out and discovered that the shaft had broken off. i bought the different VSS and all has been well for about 6 months
Old Apr 3, 2003 | 07:13 AM
Scott_92RS's Avatar
Car: 1992 RS
Dang, that sucks. I guess I'll go ahead and pick up the new VSS as well. Thanks for your help!
Old Apr 13, 2004 | 10:52 PM
87Formula4bbl's Avatar
Car: '87 Formula
Bringing this from WAAAYYYY back. Quick question, did you have any problems with the connectors between the two? Did it use the same connector or was it different? I'd rather not have to rig it up to work.
pjsparts
Oct 29, 2025 06:39 PM
GTAman
Jul 3, 2024 07:29 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
