Will a world class T-5 handle 450 TQ?
Old Jul 12, 2003 | 09:54 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have a stought 355 from my Corvette that I want to put into my 1988 Firebird. The vette engine puts out 400 HP and more then 450 FtLbs of torque, will the T-5 live behind this engine? I never power shift the transmission but I do drive it hard at road courses and the drag strip. My current 305 puts out 375 FtLbs of torque and I have never had a problem with the transmission.
Old Jul 14, 2003 | 10:07 AM
mjpell's Avatar
T-5
Even the World Class T5 is only rated at 330 ft/lbs. I think you'd be playing the odds on whether or not it would live. I personally wouldn't even try it with a small 350 crate engine. If you do, definately don't shift into 3rd hard, that's the first weak point with the T5s.
The TREMEC 3550 or TKO would be a much better choice.
good luck,
Old Jul 14, 2003 | 11:00 AM
ede's Avatar
ede
lot depends on how you apply the load too, but even with great luck you'd still be pushing it
Old Jul 14, 2003 | 03:17 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
http://www.g-forcetransmissions.com/tran_gt-5.asp
Old Jul 14, 2003 | 06:47 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
500 ft-lbs of torque. Is that for real? I didnt think the case of the t5 was strong enough for that kind of abuse.
Old Jul 14, 2003 | 07:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
looks like its got straight cut gears. Might be a bit noisy for everyday use.
Old Jul 15, 2003 | 03:41 AM
pasky's Avatar
Thats the dog gear version, they have a syncro kit available as well.
Old Jul 15, 2003 | 11:47 AM
Car: 88 Camaro SC
Engine: SFI'd 350
i saw they had a synchro version as well with helical cut gears but i dont know if it would be as strong as the straightcut that they claim is good for 500 ft-lbs. Id like to see them run live tests on trans' equiped with all the available kits so one could see how much each kit will safely hadle.
Old Jul 15, 2003 | 02:02 PM
pasky's Avatar
Actually, there was a whole big post about this site and I believe those are the stats for the Syncro's if im not mistaken, I could be wrong. Either way, just do what the people in that topic did, give them a call and ask, can't hurt . THats what im gonna be using when I get my LS1 or Ram jet .
PurelyPMD
May 5, 2016 04:57 PM
gt4373
Oct 8, 2015 10:37 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
Damon
Sep 26, 2015 04:29 PM
