Wheel Painting Results
Old Mar 29, 2004 | 07:10 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
I just got done painting my Z28 wheels and just thought I would post the results.
Ryan
Old Mar 29, 2004 | 07:23 PM
Car: 1992 RS
Engine: 3.1
Sorry, here is the picture.
Old Mar 29, 2004 | 07:57 PM
Demon355's Avatar
Nicely done
Old Mar 29, 2004 | 08:39 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Transmission: WCT5
what process did you go about painting it?
Old Mar 29, 2004 | 08:58 PM
Car: 1992 RS
Engine: 3.1
Process:
1. Wash wheels. ( 30 Minutes)
2. Use degreaser to get as much grease/brake fluid off.(15 minutes)
3. Use adhesive cleaner to remove as much grease as possible.(15 minutes)
4. Tape wheels up(I used green 3M automotive masking tape- about $7 per roll) Make sure you use a utility knife to smooth edges. The painted ring around the outside is hard to cut out. (1-3 hours per wheels- you need to take your time)
5. Spray with autobody paint. Make sure you rotate wheels as you spray to get all sections.( I used Dupli-Color DSGM 398 Bright Red). Used 2-3 coats depending. (5-10 minuted per wheel)
6. Let sit overnight.
7. Spray with clearcoat( I used Dupli-Color Clear coat) Spray clearcoat 2 times. Let sit to dry for a couple of hours.
8. Peel of tape gradually.
** If the previous paint is just discolored (like mine), there is no need to sand it.**
If you have any other questions feel free to ask!
Ryan
Old Mar 29, 2004 | 09:09 PM
Car: 1991 Camaro RS
Transmission: WCT5
I just polished my rims so i need to repaint in there
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
