What are the specs for the ZZ4 cam?
I need like lift, duration, LSA and all that good stuff. Also, where can I get it and what does it cost?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: FORMULA 350
Engine: ZZ4
GM part number>>10185071
Hydraulic roller tappet
duratation @ .050 cam lift I:208 E:221
gross valve lift(1.5 ratio) I:474" E:510"
lash Zero/Zero
lobe centerline 112 degrees
Got this info right from the catalog
lash Zero/Zero
What is their website, and it looks as if the ZZ4 cam is identical to the ZZ3 cam. Thanks
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get it from Scoggin Dickey and support our sponsor. http://www.sdpc2000.com/
I have that cam in my car with L98/ZZ4 heads and I think its great. Yes the ZZ3 and ZZ4 cams are identical.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
