Which seats will fit in my car?
Old Apr 18, 2002 | 10:03 AM
75/92 Birdman's Avatar
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
I need a set of front seats for my 84 Trans Am project, but I don't want to spend a fortune on them. I figured I could get a set of seats out of other cars cheaper than I could get a set of Firebird or Camaro seats. All I need is a set of seats that will either bolot right to the existing holes or the existing seat tracks will bolt right to the seats. Remember, this car is going to be fixed and sold, so it doesn't matter if they look right, just so that they look nice. Thanks!
Old Apr 18, 2002 | 03:33 PM
Kaps's Avatar
Grand Am seats fit in, small modification, a guy on the board did it and it looked nice. I think he replaced the camaro tyrack onto the Grand am seats and went right in. Good Luck
Old Apr 21, 2002 | 09:52 PM
Yeah, I saw that. Does anybody else know of any seats? I'm a big guy (6'5", 260lbs), so I need a wide seat. Also, I want to put these seats into my 76 Trans Am when I get ready to sell the 84 Trans Am, so they need to be a little bigger so they don't look out of place.
Old Apr 22, 2002 | 12:14 AM
2vmodular's Avatar
grandam is an "n-body". not all n-bodies had front buckets, but many did.
http://www.n-body.net/whatsbody.php
What's An N-Body?
The Basics
"N-Body" is General Motors designation for the platform that GM vehicles such as the Chevrolet Malibu, Oldsmobile Alero and Pontiac Grand Am are built upon. Although these vehicles look very different from the outside, the drivetrain and body structure are essentially identical. GM shares its various platforms with all its product lines. For example, the Chevrolet Cavalier and Pontiac Sunfire are built on the J-Body platform at the Lordstown Assembly Plant in Ohio. Likewise, the Chevrolet Camaro and Pontiac Firebird are built on the F-Body platform at the St. Therese, Quebec plant.
GM has used the N-Body platform since 1985, and since then many different makes and models of GM vehicles have been built on it, including the Buick Skylark & Somerset, Chevrolet Malibu, Oldsmobile Achieva, Alero, Calais & Cutlass and the Pontiac Grand Am. These vehicles have sold under many different trim levels with several engine options, from a 2.0L Turbo 4-Cylinder up to the current 3.4L V6.
Buick Skylark
The Buick Skylark was available from 1988-1996 in Custom, Limited and Gran Sport trim levels.
Available in 2 and 4 door configurations.
Buick Somerset
The Buick Somerset was available from 1985-1987 in Custom, Limited and T-Type trim levels.
Chevrolet Malibu
The Chevrolet Malibu has been available since 1997 in Base, LS and STD trim levels.
Available in 4 door configuration only.
Oldsmobile Achieva
The Oldsmobile Achieva was available from 1992-1998 in S, SL, SC and SCX trim levels.
Oldsmobile Alero
The Oldsmobile Alero has been available since 1999 in GX, GL and GLX trim levels.
Oldsmobile Calais
The Oldsmobile Calais was available from 1985-1991 in International, S, SL and STD trim levels, as well as special Quad 442 models.
Oldsmobile Cutlass
The Oldsmobile Cutlass was available from 1997-1999 in GL, GLS and STD trim levels.
Pontiac Grand Am
The Pontiac Grand Am has been available since 1985 in Base, LE, SE and GT trim levels.
Old Apr 22, 2002 | 12:15 AM
2vmodular's Avatar
seat width is very close between the 95' grandam seats & stock thirdgen seats.
Old Apr 22, 2002 | 12:23 AM
2vmodular's Avatar
can't go much wider on thirdgen front seats without removing the center console or seatbelt assembly.
honestly, thirdgens are a little cramped inside for us big guys. have you considered getting a fullsize car like a crown vic? http://www.crownvic.net
Old Apr 22, 2002 | 12:26 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
my mom just bought the new malibu with all the options, power seats and everything. oh man those seats are the most comfortable seats i have ever sat in. i only wish they would bolt in. and if they were in black or charcoal. but man they are sooooo comfy!
Old Apr 22, 2002 | 08:19 AM
Buck268's Avatar
2vmodular, I thought I must be the only person on here that liked crown vics! Those cars are awsome - if you are gonna go full size, go Crown Victoria! I second the link to www.crownvic.net as it seems to be a good site IMO.
:lala:
Old Apr 24, 2002 | 03:01 PM
IROCBUFF's Avatar
Car: 1987 Z-28 IROC-Z
Engine: 5.7
Seats
About a year ago I put a set of 4th gen seats (front and rear) in my 1987 IROC. They were out of a 1998 Bird. I am 6'4" and about 260 and they fit great and have greater support. They are a direct bolt in and theonly modification I had to make was to cut the seat belt support to slide the seat belt in. After it was bolted back on it is not noticable.
Old May 2, 2002 | 03:00 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I thought the Grand Am was a G-Body along with the Grand Prix. I defiantly know the Grand Prix is a G-Body...
My mom has a 99 Malibu, does it have anything to do with the Chevelle Malibu or anything, I have always wondered. As far as the MAlibu seats, I don't think they are all that, but OK.
Old May 2, 2002 | 04:03 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Grand Am is a smaller car, its only slightly larger than a sun-fire. Until lately when they got a little bigger.
John
Old May 9, 2002 | 03:44 PM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
I had '87 Grand Am SE buckets in my '89 RS and they fit perfectly. Just changed the seat brackets. They were comfy on long rides!
Chris Valk
1991 Camaro RS 305 Convertible 700-R4
3.23 (zexel-torsen) Posi out of a ’99 Z, 4 wheel disk, S-10 Flush Center Caps, Flowmaster, KYB GR-2 Shocks, ’00 WS-6 Springs, Performance Suspension Poly-Graphite Bushings, !cat
1989 Camaro RS 305 T-top World Class T-5 (rebuilt)(all RPO Codes Match except wheels, taillights and grille) 3.73 Posi, Checkerboard Taillights, 87 Iroc Wheels, N64 Aluminum Spare, Iroc Sway Bar, Power everything Flowmaster w/ dual-dual tips, 3" exaust, 91 Z Grille
Old May 9, 2002 | 03:49 PM
okfoz's Avatar
it does not surprise me that several different cars will have interchangable seats. Back in 67, my Riviera uses the same exact bucket seat as the Camaro & firebird, the only difference might be the pattern on the vinyl. The reason I know is my headrests are interchangable with camaros
John
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
