Power locks/hatch and Alarm
Old May 22, 2002 | 08:39 PM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
I am installing a alarm and was wondering what wires I needed to tap into for the power locks and where those wires are located. Also how do I wire in my power hatch? What kind of circuit is it? And the last one, Do I need to install a trunk pin or is there I wire I can connect to.
Thanks Alot
z28redline
1986 z28 Camaro LG4
Old May 23, 2002 | 11:20 AM
2vmodular's Avatar
Information below is unverified, use at your own risk. Also, do not attempt to wire remote start into a vehicle with a manual transmission.
Make: Pontiac
Model: Firebird, Trans Am
Year: 1982-84
Alarm
Function Color Location
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT PIN SWITCH
Trunk Pin Switch WHITE (-) AT TRUNK LIGHT OR SWITCH
Parking Lamp BROWN (+) AT LIGHT SWITCH
Power Lock L BLUE DRIVER KICK #202
Power Unlock BLACK PANEL
#202- See Positive Pulse Door Lock Diagram.
Accessories
Window Up D\ D BLU P\ D BLU/WHT @ MAIN #213
Window Down R/ BRN S/ TAN SWITCH
Ign Key Warn L GREEN (-) STEERING COLUMN HARNESS
Trunk Release N/A
OEM Horn BLACK (-) STEERING COLUMN HARNESS
Headlights YELLOW (+) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A
OEM Alarm Disarm N/A
#213- See Reversal Rest At Nothing Power Window Circuit Diagram.
Remote Start
Tach Signal WHITE DISTRIBUTOR *
Ignition #2 ORANGE IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety ORANGE/BLACK (-) SWITCH BELOW CONSOLE
Brake Light L BLUE (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) SWITCH BELOW CONSOLE
Rear Window Defrost
* Some Models Carburated.
2vmodular's Avatar
Make: Pontiac
Year: 1985-92
Alarm
Constant 12 volts RED & RED IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS Dome Light WHITE (-) AT PIN SWITCH OR COURTESY LIGHT
Trunk Pin Switch WHITE OR BLK/ORG (-) AT CARGO COMPARTMENT LIGHT
Accessories
Window Up D\ D BLUE P\ L BLUE @ MAIN #213
Window Down R/ BROWN S/ TAN SWITCH
Trunk Release BLACK (+) AT RELEASE SWITCH * #231
OEM Horn BLACK (-) STERING COLUMN HARNESS
OEM Alarm Arm N/A
OEM Alarm Disarm L GREEN (-) IN EITHER KICK PANEL
#231- See Positive Pulse Trunk Release Diagram.
* Trunk Release Has Also Been Found As BROWN (-) At Trunk Release Switch (From Install).
Remote Start
Tach Signal WHITE AT DISTRIBUTOR OR DASH TACHOMETER *
Ignition #3 N/A
Neutral Safety ORANGE/BLACK (-) GEAR SELECT SWITCH
Brake Light L BLUE OR YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) GEAR SELECT SWITCH
Rear Window Defrost
* Some V-6 & V-8 Models Are Electronic Fuel Injected. Rest Are Throttle Body Injected.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
