TPI Fuel Rail Fitting Size???
Old May 23, 2002 | 10:36 AM
Tuned Port CJ's Avatar
I'm in the process of swapping in a TPI 350, and got the Accel TPI -> -6an fitting to adapt the fuel lines, but only one of them fits the fuel rail. Are the TPI fuel rail fittings the same size? both of the adapters are the same, but one doesn't come even close to fitting. Any other ideas on how to adapt the fuel rail to a total custom fuel system? Finding the oem lines is not an option. New ones are too expensive, and there isn't a used one here (Italy). Thanks in advance. Nick
Old May 23, 2002 | 10:42 AM
tpi_roc's Avatar
The fuel rail has 2 different sizes to prevent crossing the feed/return
Old May 23, 2002 | 10:57 AM
Morley's Avatar
The fuel lines for TPI are not AN style. The line itself has a flare on it that fits up in the fitting on the manifold, the line also has the nut on it that screws up into the manifold side and they are NPT nuts, like brake lines.
Nice of GM to use a system like this that can't be played with, huh?
~M~
Old May 23, 2002 | 12:00 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I just finished swapping a TPI intake into my dads 77 vette. I used power steering fittings. I am not sure what size. If you check back I will try and post that info soon. I think the threads are M18 but I am not sure of the dia.
Old May 23, 2002 | 01:13 PM
89ProchargedROC's Avatar
www.anplumbing.com
check for sawignaw adapters.......
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
knight72
Aug 10, 2015 09:32 PM
92projectcamaro
Aug 6, 2015 01:20 PM
